Sponsored by: Innova
Direct Battery Connection Inside
Old Dec 9, 2004 | 11:06 AM
tocoman's Avatar
tocoman
Default Direct Battery Connection Inside
What's the simple way of getting a direct battery power inside a 2003 C5?
I already have some items connected to the accessory wires within the fuse pannel.
I'm going to install heated seats and the recommend connection is direct to the battery with a 10 gauge wire.
Old Dec 9, 2004 | 01:42 PM
leolufse's Avatar
leolufse
The short answer is no. Its easy to remove the trim under the glove box and drill a small hole through the firewall to the right of the main wire harness when looking towards the front of the car. You can connect to the accessory post on the underhood fuse box.
