box building question for the experts
Thanks in advance
The diagram of the box you have will work just fine. Its a similar style to what you might see in the back of an extended cab pickup truck.
Actually, this is one of the prototype subwoofer boxes for the C4 storage compartment that Subthump will be selling to C4 owners. This is, of course a rough design, not carpeted, not put together yet quite completely, but at least this show's we're dong something
Finally, c4 owners will just be able to buy a drop in box.
I still have to add a bunch of stuff and do a final acad drawing, but this is the basics.snoopdan
Box A is 32" x 14" x 1/2" (for the cover plate), and vaguely 10" x 8" x 12" for the recessed storage compartment enclosure. It comes in 8" and 10" driver size. This box is about .5 in displacement. Good enough for an 8 definately, kind of anemic for a 10" driver. This may change a little before its all said and done, and overall volume is going to be closer to .75 cubic feet. It can be installed without having to cut off the scissor jack mount, and leaves space around it for brownbread or dynamat insulation, or whatever you like to use. It sits a bit funny in the back of the car, and when the carpet is layed back down, it raises the floor height by 1/2". to make it look right, you will have to buy a piece of wood, and cut it to be around 32"x 20" to bring the floor back up to level. We figured that at LEAST a vette owner who is doing all of this DIY should be able to go to Lowes and have a peice of 1/2" wood cut for this. Its not that complicated.
Here is a pic of the storage box enclosure, just so you all get an idea of what you will be buying, when these become available. Remember, this is a Prototype, and sort of ugly right now. Some carpet and paint would go a long way at this point. But I wanted to all to see what ive been up to.
Box B is exactly like Box A in its design, except it will raise higher than the floor, and be around 9" in total heigth, spanning between the inner fender wells of the back of the car. This box, will of course not fit convertables. I dont have a convertable vette anymore, so I cant try out the box. If anyone lives in the Lousiville / Elizabethtown / Corydon, IN or west Kentucky and has a convertable C4 vette, id love to try out my box in your ride. But until that day, it will NOT be for convertable C4's. This box will have an air space of around 2.2 cubic feet. Enough for two 12" easily.
Both boxes will be sealed from Subthump, and if your particular subwoofer application needs to be ported, BUY A HOLE SAW BIT, and some PVC piping
Ive been also been toying around with a single 12" folded horn box, but I dunno on how much demand there would be for it.
any suggestions? comments?? Greatly appreciated.
snoopdan
A little acousta stuf / pollyfill is great for reducing standing and canceling waves in a sub box. Of course, I dont need to tell you all that. I think this C4 stealth box would be great with a JL W7 8" sub. It would have no problem fitting in it. And thru all my 8" driver research, the JL 8" (heavy eight) sub is the meanist on the block.
snoopdan
