Clear Coat Help
GT
1) Testors clear (rattle can or airbrushed): pretty straightforward but takes a while to dry and you need to use a polishing system for a really great shine (like the micromesh system). One really big drawback... Testors clear tends to yellow (badly) over time.
2) Tamiya Clear or Mr.Color Topcoat (Gloss): Both are rattle can acrylic lacquers, easy to use, 2-3 coats yield an awesome shine, and dries to the touch quickly (takes about 2 weeks to fully setup). I've used this stuff for years, both on contract builds & my own projects. I love both products but they can be tough to find and a bit expensive.
3) Zynolyte (sp?) crystal clear: Well, I think it's still called crystal clear??? Anyhow I used this spray enamel a few years back almost exclusively. It was dirt-cheap but provided an excellent finish. After applying 2-4 coats then sanding & polishing with micromesh, you'll end up with a glass like surface. I used it on a McLaren MP4/6 about 12 years ago... Still no yellowing.
4) 1:1 scale car paints: You can go this route as well but be careful!!! Some touch up paints or auto paints in general can do nasty things to plastic kits without a primer or barrier coat. Test on scrap plastic first!!!
5) Future floor wax: I'm not insane... It works quite well and when carefully applied with a wide flat brush (with very slow & smooth strokes) you can end up with a phenomenal finish. Normally one coat is all you need, just keep the model away from any dust for a good week to really let the stuff setup. I’ve used future on my aircraft model canopies for years, as well as some of my car models. Recently I did a rush job for a customer and glossed a Ferrari F2001 with future because I didn't have time use other techniques. It's still glass like after 3 years. A word of warning... Using future takes practice & patients; also, the older formula can yellow over time.
Think that's about it for now, hope that helps a little!!!
A'hui hou,
Mark
