Auto Extras & Memorabilia Accessories for your Corvette that aren’t budget-busters. Plus, Corvette memorabilia and die cast models (1:24 and 1:18 scale).
Decal maker
Old Feb 5, 2006 | 05:05 PM
copter's Avatar
copter
Default Decal maker
Just got back from my two closest wal marts and they we both out.One did have a mangled up box with the little cd rom missing.I read the box and outside of making little license plates and flames what else do they do?What if I wanted Vette emblems and such what then.Are these worth it?
Old Feb 5, 2006 | 05:09 PM
bub's Avatar
bub
Note: White will not come out unless you are putting the decal onto a white surface.
Old Feb 5, 2006 | 06:47 PM
copter's Avatar
copter
Do you have one?I was just wondering what the limitations are.
Old Feb 5, 2006 | 10:37 PM
bub's Avatar
bub
Yes. We did some C5 logos a while back with it for 1:18 UT repaints. Had to use a small section of white film under the crossed flags to make the checkered flag on a red car. PITA, but it can be done with patience.
Otherwise the decal kit is quite good, and if one could get a white ink printer (I hear they have these now?) to work with its software provided, that would be even better.
Old Feb 6, 2006 | 09:13 AM
Scott85's Avatar
Scott85
www.decalpaper.com
You can buy the decals sheets in white, just take your time tracing them out.
Old Feb 6, 2006 | 05:35 PM
copter's Avatar
copter
Where do you go and get the script ect.to make the decals.For example if I wanted a 1/24th or 1/18th 78 pace car set?or the nose and rear deck emblems.
Old Feb 6, 2006 | 07:11 PM
7Vette's Avatar
7Vette
For 1/24 '78 pace car decals, you don't need to make them. Just use the decals from a plastic model kit. I made a handful of Franklin Mint '78 pace cars long before FM came out with their sad version, and I used the decals from the Revell kit. As for 1/18 78 PC decals, you can enlarge them from 1/24, but you won't be able to do the silver parts on a regular printer. You'd need an ALPS printer to do silver, gold, & white.
For making emblems and script decals, and just about anything else, find a photo of what you need on the internet (Ebay, Google images, etc.), size it in Photoshop, and print it.
Old Feb 8, 2006 | 06:35 PM
copter's Avatar
copter
Thanks 7vette.I can do this!!Now I just have to wait until wally mart restocks.
Old Feb 8, 2006 | 11:15 PM
7Vette's Avatar
7Vette
Craft stores are another decent source of small kits. If you have a Michael's or Hobby Lobby, they stock a good selection. Regular hobby shops can be a bit pricey on kits. If you do Ebay, sometimes you can get kits dirt cheap, even with shipping tacked on. For $3, you can order just the decal sheet straight from Revell. Also, make sure you get some decal solvent. It'll help avoid a lot of headaches when you're applying the decals, especially on the compound curves around the wheel flares.
Old Feb 9, 2006 | 04:55 PM
copter's Avatar
copter
Ok,I've both decal solvent and decal set.you say revell sells just decal sheets?Don't have a hobby lobby but do have Michaels.
Old Feb 9, 2006 | 05:55 PM
7Vette's Avatar
7Vette
You can get replacement kit parts from Revell on a limited basis, and there's a $3 shipping charge. You can just buy as much as you want, you have to be prudent about it.
Old Feb 9, 2006 | 06:32 PM
copter's Avatar
copter
I just a simple southern Gerogia boy.What does prudent mean???
Old Feb 9, 2006 | 06:54 PM
7Vette's Avatar
7Vette
Basically they'll supply replacement parts that are missing or damaged in the kit. They don't just sell parts/decals outright. I actually had a kit that was missing the decals altogether, and they replaced them. They have limitations on the quantity of parts you can get. You can check it out here...
Revell parts/decals
Old Feb 9, 2006 | 07:50 PM
copter's Avatar
copter
Thanks for the link 7vette.
Old Feb 13, 2006 | 01:00 AM
IWAVE2's Avatar
IWAVE2
Can somebody tell me what kind of images that the software has available on it in this kit? It says on the box that you can make license plates. Does it provide templates or patterns for all 50 states' license plates? If not, what does it provide? I would just like to know if it is worth spending the $8.00 just for the software. Thanks for any information.
Jon
Old Feb 13, 2006 | 01:09 AM
7Vette's Avatar
7Vette
Here's a good place to use for license plates...
Acme license maker
A tip for making scale license plates: they don't have to be decals. I just made a set tonight for my '69 Cougar, and I used Kodak glossy photo paper. Since many license plates have either white backgrounds or white letters/numbers, you don't have to worry about not being able to do white on a regular printer. After you've printed what you want, cut it out, round off the corners, and glue it onto the plate holder. The main advantage is that you don't have to do any decal sealing, etc. With photo paper, just print & go.
Old Feb 13, 2006 | 01:52 AM
IWAVE2's Avatar
IWAVE2
Acme license maker
7VETTE,
Thanks very much for the tips on license plate making and the website. That is just what I have been looking for. I used to make license plates on decal paper, but sometimes that just doesn't work well. I found some inexpensive Sticker Project paper at Wal-Mart that I have been using. It is slick white adhesive backed paper that you can print photo quality images on. It is not glossy, but it is not as grainy as plain paper either. The images print clear and I just cut them out, peel and stick. Thanks again for the help. Take care.
Jon
Old Feb 13, 2006 | 01:54 AM
7Vette's Avatar
7Vette
Glad to help Jon! It sounds like the sticker paper is a good way to go as well.
Old Feb 18, 2006 | 11:13 PM
124parkdrive's Avatar
124parkdrive
Default For best results in making decals
Get an alps printer. This is the only printer that can print white or metallics. The are pricey though and no longer made for consumer use.
To Decal maker
