FS: TCE: offering a little something or everyone...
#66
Former Vendor
With more and more folks considering the Larger 20mm pad Aero6 caliper for their track day need TCE is now stocking the 20mm pad options for this caliper. We will be stocking the popular Poly A, B and H compounds for customer needs.]
The TCE BRAKE PAD PAGE has been re arranged a bit to put both pads and pad wear plats and Ti Heat Shims in the same location. Less searching for what you need; pick some pads and below that see the optional plates and shims you may wish to add for your purchase.
The SERVICE PARTS PAGE has also been updated a bit to give you real world images of the parts available to service all your Wilwood needs. Find seals, bleeder nipple caps, clips and hardware.
In other Custom News we recently wrapped up a custom build for a Buick Wildcat. There's one you don't see too often. This is a front and rear 14" kit with Aerolite calipers on all fours. Some sample images below, we're eagerly waiting for the final "on car" pics to show you more.
At TCE we like Corvettes as much as anyone but there's a world of other vehicles out there just dying for some brake love...what can TCE build for you?
#67
Former Vendor
June update
Haven't had time to put up much of an update lately with multiple shop projects but we do have news to share!
DUST WIPE CALIPERS:
One of the ongoing questions about the use of Wilwood calipers for the street has always been the lack of dust boots. While most feel it's not really an issue it's clearly had others look elsewhere. Today there's an alternative: the Dust Wipe shod Wilwood caliper. The caliper now has an outer 'wiper seal' to stave off the common dragging of grit into the seal area at the time of pad change- the number one cause of caliper contamination. With the dust wipe in place you have greater protection against internal damages or ingestion of brake dust, water, grit, and anything else that seems to be in the way....
While they are not "BOOTS" (they do not extend with the piston), they do have a place in the daily driver application for sure. And not being boots they will be more tolerant of high heat demands on an occasional track day. They will now allow many of the calipers/kits meet Euro standards for secondary seals and boots. *Your regulations may vary.
These new seals are being installed in a vast number of calipers including the very popular Aero4/6 models as well as FNSL4/6- off of which are the most popular on the Corvette platform. At this time they will be an optional "upgrade" for a cost of roughly $100 per kit. They are not yet being supplied by default into your kits so you do need to contact me directly for any orders. They are not available in dedicated "race" applications such as the AER6-ST with Thermlock pistons. Think street market please.
INTERNAL CROSS OVERS:
Another change across the line is the implementation of internal cross over fluid bodies. Recent changes in body production including stress flowed forgings has produced an improved and stiffer body. That in turn has allowed the ugly old cross over tube and fittings to be removed on many calipers. This began some years ago with the Aerolite line and have now made their way into the FNSL line as well as the smaller DL line. The DL models have also sprouted larger body bolts now for greater body stiffness. Seems pretty much a win-win deal for the smaller class caliper.
Speaking of the FNSL6 caliper.....today we have a new six pot model displacing 4.86" of piston area bringing the family to three: 3.46, 4.04, and 4.86". Why the change? Many applications today need a larger displacement and to do so required the use of the (larger bore) FNSL4 to get the proper area desired. And of course most consumers hear "four pot" and immediate feel it's inferior...."six pot" must be better, right? Well...not really but yeah I get it and marketing being what it is you now have an equally effective SIX pot to match up with the common four pot rear kits. Again; a winning combo!
While on the topic of Winning TCE took to the races a few weeks ago and set fast Qualifying and Race times in the first race of the 2018 season. With a three car team we rely on Wilwood for all our braking needs. From calipers and pads, to masters and fluids...even wide five hubs on the 4 car. TCE not only sells Wilwood, we rent it (two car rentals) and win on it. What's stopping you??
WHAT CAN TCE BUILD FOR YOU?
DUST WIPE CALIPERS:
Come along for the ride: RACE DAY RUN II
#68
Former Vendor
C5 and C5 Owners: Wilwood Race Kit Special.
As of late Wilwood has opted to cut use of the Nickel plating on its calipers. To that end we are removing this option from the pages that listed them- both full kits and the Caliper Kits.
But.....checking inventory there are a couple of Wilwood Race Kits available yet with this fine looking finish. What is a "Race Kit" you ask? This kit is assembled using the nickel plated Arero6 caliper with the fatter 20mm pads, in the proven Poly H compound. It also has Wilwood insulated Thermlock pistons for greater thermal barrier protection and comes with Dynamic Mount full floating hats/rotors. Prod #: 140-13743-N
TCE is including our dedicated C5 or C6 ss flex lines and 2 bottles of Wilwood EXP fluid with each kit.
To help clear the shelves TCE is offering you this entire package for $2589 to the door. (US) That's the full front kit as noted above, ss flex hose kit and EXP fluid all to you by way of Brown.
If you've been looking for a track kit deal this may prove your one opportunity to score big on this sale.
Similar savings can be had on front and rear combo purchases also. Please inquire.
*All sales above by phone order. Ground UPS, US mainland only. Customer to verify wheel fitment. All sales final. No substitutions allowed.
#69
Former Vendor
Been quite a while since I passed through and shook things up a bit. Some UPDATES.
As Arizona's largest Dealer and one of the Nation's most experienced, TCE brings 25yrs of Wilwood knowledge and commitment to excellence to the table. As I've said before: I don't just sell it....I design and build it, I race it and I support it after the sale.
The shop business has exploded over the past ten years taking on a more "custom" nature. We remain Wilwood's first choice for referral work and come highly recommended by Jeggs, Speedway and Summit Racing. When they say no we don't have call TCE that means a lot. Not every request is a home run but many have led to repeated sales of mid 60s Caddys, Fiats, Older Buicks, a MB190 and even our own Mustang IRS rear kit with parking brake. If you can dream it we can probably build it.
Let's talk parts: TCE has a wall full of component parts to service your Wilwood calipers. Be them a year old or ten or more we can probably still get, or have, the parts needed to do you year end freshening. Pistons, Seal Kit, Pins, Clips, Bridge Bolt and Hat Bolt Kits, Bleeders, Fittings....and plenty of pad options with over 300 boxes in stock from two pot Dynalites to Six pot TX6 truck calipers, and of course all the popular Corvette parts: FNSL and Aero/W series calipers.
Check the SERVICE PARTS PAGE for your needs.
Bumped into a few Nebraska owners last weekend while visiting my Father In-law and took in some AX action out at Lincoln Airpark. Nice bunch of people.
From the Racing front Team TCE has completed the short but full season of CHCA hill climbs winning all four of our class races and setting a new record on the new Rangely course in NW Colorado. Along the way we managed a couple of top five overall finishes of 60-80 competitors beating more than a few 'big motor' cars. While all that was good we threw a rod at the last race making for terminal damage as well. *Despite that our first run held for the quick time, win and record!
Teen Driving Programs: being busy this year I managed but one event with Ford Driving Skills For Life. Folks: if you have a teen or a grandson/daughter please consider giving them the gift of driving. While the Ford program is FREE, consider any of them to be a good investment for your budding driver. Most require some 'wheel time' as the kids are put through more advanced exercises; skid control and accident avoidance. All good stuff so please; spread the word.
Continued PM, open discussion and private email or phone calls from all of you are greatly appreciated. Any questions please ask, that's what I'm here for.
#70
Former Vendor
Hello everyone!
Welcome to the 2019 prep season!
Figured I'd "throw you a bone" and spruce up the TCE deals with a bit better deal. How's that? Easy!
Purchase any TCE 4X combo kit between now and May 10 and get 25% off your additional pads purchase. Yep; 25% savings on all pads, street or race. Stock up now for the race season or just put some on the shelf for your future use.
Use the TCE check out for your kit purchase, add your pad options to that purchase and place your order. TCE will refund you 25% off the pad total back on your cc or pp purchase. Or you can call/email/pm me with your desired pads and we'll gladly send you a payable invoice in advance reflecting the discount. Either way you SAVE BIG!
Need some popular H pads for your Aero6 purchase? Normally $208....with your 25% savings: $156 with Kit purchase. Extra BP20s for the future? Normally $90, with kit purchase $67.50.
See the entire pad line option HERE
FINE PRINT: Must purchase 4X Four Wheel kit. Pads limited to those required for kit. Must be ordered and paid on one purchase. Limit 3 boxes per order. Limited to pad compounds listed on TCE Pad Page. Pads ship with ss flex lines from TCE
#71
Former Vendor
Greetings everyone.
Want to let you all know that TCE will be taking a 'hiatus' from Corvette Forum for a few months. We'll go dark the end of this month. No doubt posting privileges will be nixed and possibly older threads removed. The shop has been busy with a lot of custom work lately (finishing up a SEMA project for a name builder today) and I have not had the time to dedicate to the Forum that it takes to justify the cost being here. You pretty much need to be on top of the site day in and day out with something to offer and I simply don't have the time and energy to blast out daily specials and discounts.
Not to fear however; the shop's not going anywhere! Still here to offer you the best value in all Wilwood kits, parts and service. I'll likely re-up in the Spring in time for your track prep needs and sunny weather.
In the mean time you can still find TCE on the webpage (with our exclusive 4X listings), on Facebook and on Instagram.
Thanks to everyone who's been supportive of the business. Truly appreciated! If I don't hear from any of you until next Summer I hope you all have great Fall and holiday season.
smitty2919 (11-16-2019)
