FS: Tire Pyrometer
Tire Pyrometer
After many years of track days and measuring each tire temperature manually, we knew there had to be a better way. Tire temps are crucial to get the power down. We developed a Tire Pyrometer using infrared tech to measure tire temps in realtime; all four tires, or just the rear for you drag racers. Price is $199. The 4200 model measures all four tires. The 2110 model measures just the rear, and has LED's that light up as the tire heat up.
See our website for more info.
NHXracing.com
NHXracing.com
The 4200 model has four sensors, one for each tire. The 2110 model has two sensors, one for each rear tire (or front tires for a FWD). The sensors measure the average surface temp of each tire.
We have also developed models to measure multiple points on each tire. PM me or contact us on our webpage if that's what you are looking for.
With this pyrometer, you can see tire temps change as you hit corners and see how this changes taking corners at different speeds or different lines. It also allows the driver to see how tire pressure changes impact the heat at each corner. You'll also see temps temporarily jump up with wheelspin or lock up.
I think you would have a larger market if you could integrate your sensors into existing systems than if you create a new Data acquisition system. Here is a view from my AIM system... it would be great to have real time tire temperatures on the video for analysis, but it isn't very helpful if it is a new stand alone system.
Just my thoughts.
Charley
