FS: NEW - Peterson 3 Gallon Dual Scavenge Inlet Dry Sump Oil Tank, with Brackets
NEW - Peterson 3 Gallon Dual Scavenge Inlet Dry Sump Oil Tank, Brackets Available
sold!!!
Last edited by kmagvette; 02-25-2019 at 07:48 PM. Reason: Made brackets optional, lowered overall price.
Did you find a different sized tank to replace it? I have a 2 1/2 gallon Peterson tank that is new with a few slight scratches and willing to trade plus $100 as I don't have the mounting brackets. It's 6" X 24". It has dual 12AN inlets and a single 12AN outlet plus a 1/2' npt bung for a heater.
I have my solution. Did a bunch of measuring and had Peterson build a custom 7" tank. After mounting I have a solid 1/16" clearance between the top of the tank and the hood. I may have been overly concerned about proximity of wires to the tank. Final solution I went a little nuts heat shielding everything from the tank. Guess anything worth doing is worth overdoing.
kmagvette did you get the tank already?? I requested the fill hole and cap to be offset from the top to gain even more clearance. Can you send me a PM with a pic of the tank.
