Getting sick and tired of breaking rear diffs!!!!!
This is ridiculous...I just broke another rear Monday at Summit Point. I was only 8 laps into my first session...and just gettung the tires up to temp and bam...stinky diff fluid and the dreaded gear whine!!!
Once they replace this rear, I will now be on my 4th rear in less than 2 years...what gives? I NEVER drag race the car and drive really smooth on the track...no more abusive than 1/2 of the guys on this forum and racing T1. What gives...does anybody know what could keep causing my rears to break...I am beyond fustrated.
Received 8,958 Likes
Are you overheating it? I lost the diff on my 97 at Watkins Glen after a particularly hot day with some really long sessions. The next day it was howling.
Bill
Bill
This was the first session of the day on a completely new rear...and I only got 8 laps in on a 60F day before it broke. I can't imagine the rear was up to temp.
What year car and what gears are you putting in it? Exactly what is breaking?
I went with the HD 3.73's from Randy's Ring and Pinion and am pushing 400+ rwhp. These gears come with a D44 ring gear and a D60 pinion gear. They come in a Yukon box but they are Dana gears (etched into the gear).
Mike
Mike
Originally Posted by cyclerage23
How much power are you running? D36 or D44? When you are replacing these, what are you replacing? Maybe your housing in warped?
The car is an 01 z, so I imagine the rear is a 44? They first time they replaced the entire rear assembly, the second time they only replaced the ring and pinion. The motor is stock except for intake, headers and exhuast...no big power adders
They probably didn't rebuild it properly. I bought two NEW 3.42 rears from GM. One when it blew up in April. The car was back together in Sept. The first one went bad in 400 + miles so I bought a new one in Sept. 400 + miles later it was bad. NO abuse on either just breaking in the motor on the street. Number three has been fine. I guess it's really the 4th in the car counting original.
We'll you making me feel better that I'm not alone, but that is absolutely ridiculous...I have never heard of this being such a problem with corvette's.
Bill
The car is under warranty, and they are replacing the entire rear assembly...again. That is the good news...the bad news is that it will take about 3 weeks. They think it is a deformed/warped or improperly machined housing. I hope this gets it!
With that said, I won't be seeing you guys at Pocono until June or July. I have called to cancel this Saturday on the East course, and have to cancel next Friday with CART. This really sucks
I read somewhere that it takes 500 miles to breakin and if you get on it hard (track) that it will not last very long. seems that they may need to work harden after a new install i think it was a GM tech bullitin
mine went bad...the dealer I go to is pretty large and well know (Terry LaBonte) so they just said "we cant pin point the problem, so we are going to replace everything". Sure enough, everything is new and no problem...i did spend 500 miles driving EASY before getting on it again.. good luck on the next one
First off, let me say I have never worked on a C5 rear. I know C5s have a transaxle and subsequently a heat issue. I have setup gears on 12 bolt GM rears, Dana 44s and have rebuilt numereous transmissions. I don't know your break in procedure but when I do a ring and pinion, I run the car on jack stands and monitor the temp. I let it cool, drive it for 20 minutes in street driving and pull over and check the temp. I used to just use my hand but now I used an infrared gun. Too much heat kills these thing and destroys the lube also. I realize you may not have time to do much street driving if you have a race car. Therefore you need to get the parts bedded in without having an extreme heat issue. After a little street driving I would suggest getting a load on the ring and pinion by making a hard 1/8 mile run followed by a cool off period. I'm talking about being able to hold you hand on the rear for 3 seconds without cooking yourself. Then some 1/4 mile runs, again cooling off between runs. The worst thing to do is to hit the track for 20 minutes without doing anything prior. You have to give everything time to loosen up and bed in. Pinion bearings have preload as well as carrier bearings for the differential. Change your lube before you hit the track. Change it again after the event. It's cheaper than replacing rears. You'd be smart to run 1/2 of a session each time the first day out. Pull into the pit area and use an infrared gun. I'd like to see 200 deg. but I doubt that's going to happen. I'd say if it gets to 225 I'd be quitting and letting it cool off. That's plenty hot for the first day. Most lubes start to breakdown at 250 or so. I'd use a good synthetic, Mobil or Red Line.
I know you C5 guys absolutely need coolers and I suspect a good many of you need to change lube more often. Obviously a cooler will prolong lube change intervals.
Originally Posted by John Shiels
Matts roasting them tranny next
Not sure how much longer that thing will last...they had several blown up LS6's at Pheonix. I'm talking rod through the block grenade, with a salad of metal parts inside...need to get that warranty
extended
Mike
Originally Posted by luvmy92
My feeling is if it's going to go, it's going to go. Why beat around the bush?
Mike
Mike
Now if yours doesn't break Good! and I really think I'd have a hard time staying off it for that long also.
