Blue Devil Info.
Old Jul 5, 2005 | 08:27 PM
bpirate's Avatar
bpirate
In most instances weight is a major factor in aircraft design for a multitude of reasons, besides when you hit the ground at 400mph it is not going to matter if it is Al or steel.
Old Jul 5, 2005 | 08:34 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I think it's the GM way of dabbling in aluminum in small numbers for production uses elsewhere. Audi has been using it a few years now. I think the cost factor in amatuer racing is a big problem also.
