C5 G-Force Harness Questions
Looking at these models to pass through my sport seats via the AZ Speed and Marine bar.
http://www.saferacer.com/prose6pthcah.html
or
http://www.saferacer.com/prose6pcahas.html
1) Which one is better and why?
2) Do I want "pull up" or "pull down" lap belts? I know this is probably personal preference, but this is my first harness so I could use some advice.
3) Is this the best anti-sub for my stock seat?
4) I need the G-Force clip in points for the BK lap kit, right?
Thanks In Advance
or
Thanks In Advance
[QUOTE=BQuicksilver]Looking at these models to pass through my sport seats via the AZ Speed and Marine bar.
This one. It has the wrap around shoulder belts. The other one is bolt in. You will need to purchase 4 of the clip in parts for the lap and sub belts.
or
Shoulder belts are all pull down. The lap belt is the one with the choice. I have the pull down, but think the pull up would be easier. With the pull up, the door and the seat don't get in the way of tightening the belt.
Don't really know about that. I've read that this is the best type so the boys don't get smashed too badly in and accident.
Yes. Two for the lap belts and two for the sub belt.
or
Thanks for the great reply! Just few questions left.
Can't you add clip in ends to the other one? I was asking more about the H in the upper straps. These will be passed through the sport seat I believe unless passing them around the seat is safer. Not disagreeing with you, just want to make sure you knew the difference I was concerned with and that I'm using sport seats.
Also, can anyone double-check that these will work at all in a C5? Hopefully the measurements aren't totally off.
Again, thanks! I agree, my only concern would be if there was too much bulk in the middle with pull down uppers and pull up lowers. If it's not an issue I think that question is done.
or
or
[QUOTE=BQuicksilver]Thanks for the great reply! Just few questions left.
The bolt in ends can be replaced by the clip in ends. Doing this to my own set.
I alo have the sport seats. You don't need the H strap with the sport seats. Pass the belts thru the openings and you are all set. The H strap is a necessity if the belts have to go around the side of the seat.
They all have alot of adjustment.
Again, thanks! I agree, my only concern would be if there was too much bulk in the middle with pull down uppers and pull up lowers. If it's not an issue I think that question is done.[/QUOTE)
There shouldn't be too much bulk around the latch of in your lap because the ends of the belts where they mount can be adjusted so that the belt at the adjuster where you tighten them will have only a couple of inches hanging loose. I have the pull down lap belts and I usually have to adjust only one side. If you don't move the side against the console, you can latch the belts and then tighten the lap belt by the door. If you leave the door open a little, it easy to do. Just don't leave the door all the way open or you won't be able to reach it after the belts are tight.
Received 8,961 Likes
Bill
Went to the first link and it says 6pt and then shows 5 pt. FWIW I got a Crow http://www.crowenterprizes.com/ go to
products and then scroll down and there is a Corvette specific 6pt. system for the sport seats and the pass through. Only issue I see is if you are tall like me you need the mounting point low to keep a fairly straight line from mount to shoulder. I don't think you would want the belt either pulling the seat up or down.
specific model:
http://www.crowenterprizes.com/shop_...asp?sku=1114-C
As to the pull down on lower belt, you have no leverage with your arm close to the body so it is difficult to get tight. With the pull up, if push comes to pull you can get some one to lean in and pull up, which is what they do in the formula cars. Also, with the clip, then overlap of material, then loop through clip, then camlock, and same on other side I find the belt is fully cinched at the ends of the fold over stichting since the brackets sit up some on the seat sides. I'd check to see if a non Corvette specific model might be too lose.
Randy
specific model:
Randy
