fluids for tranny diff
Old Oct 19, 2005 | 09:16 AM
dsamford's Avatar
dsamford
5th Gear
Default fluids for tranny diff
I need to change tranny and differ fluids in 04 Z06. Warning light came on at TWS. What kind should I buy? also how much does it hold? Thanks in advance.
Old Oct 19, 2005 | 09:39 AM
96CollectorSport's Avatar
96CollectorSport
From: If you don't weigh in you don't wrestle Road America
I've had good luck with Royal Purpal
SycroMax Tranny Lube designed just for manuels that use ATF - about 3.5 quarts
MaxGear Diff fluid for the rear end - about 2.5 to 3 quarts
Old Oct 19, 2005 | 09:43 AM
gmblack3's Avatar
gmblack3
Diff holds 1.6 qts, so get 2.
Tranny holds 4qts, but you will only get 3.25 out/in.
I would recommend the amsoil severe gear for the diff and their ATF for the tranny.
Send a pm to subdriver as he is the amsoil sponsor here.
Using amsoil some need the gm additive in the diff some do not.
Make sure the car is level for the fill. Do not overfill the diff as it will cause the seals to leak. Some actually run the diff a hair low for track use.
I think amsoil also sells a fluid pump or you can get that at the local parts store.
Old Oct 19, 2005 | 09:44 AM
gmblack3's Avatar
gmblack3
The diff in the C5 hold less then 2qts.
Old Oct 19, 2005 | 10:10 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Redline D4 in the trans, Redline 75W90 in the diff.
Old Oct 19, 2005 | 10:22 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
We have had good luck with Redline MTL in the tranny, and 75w90 in the diff. 2 for diff, and 4 for tranny.
Randy
Old Oct 19, 2005 | 10:56 AM
dsamford's Avatar
dsamford
5th Gear
Default fluids
Thanks for the help
Old Oct 19, 2005 | 12:20 PM
just_trev's Avatar
just_trev
I previously used Redline MTL in the tranny and I was getting high transmission temp alarms almost every run session. I put Redline D4 in the last time and have not seen a high temp alarm since. Redline D4 is the synthetic equivalent to Dexron which is what your owners manual calls for. I also noticed there was some varnishing from using the MTL and i is quite a bit thicker than the D4.
Old Oct 19, 2005 | 04:12 PM
Lancer033's Avatar
Lancer033
personal opinion. I use Royal Purple because a local shop carries it. I doubt that it's any better or worse than Redline, AMSOIL, or Mobil 1, just easier to get. All 4 are good quality synthetic fluids and you can't go wrong with any of them.
Old Oct 19, 2005 | 07:59 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks for the mention.
As he indicated, I use the AMSOIL ATF in my tranny and the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 in my diff for my SCCA T1 car and have had very good results with it. My car is still on the original stock tranny and diff after something like 15k street miles, 10 DE days and 28 or so SCCA races without any rebuilds (though I am planning one this winter just as a precaution).
Preferred Customers save about 25%.
AMSOIL Preferred Customer Program
If anyone has any questions, please don't hesitate to drop me a line.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Oct 19, 2005 | 08:57 PM
davidfarmer's Avatar
davidfarmer
I've always run Mobil 1, they are readily available at your local Advance/Autozone, and work very well. They have never let me down.
Don't forget the diff additive (GM and Ford both work fine)
To fluids for tranny diff
