Best way to instruct "non-heel/toe-er"?
Former Vendor
1 Post
Now to make it even worse, most of my past race cars (Datsuns) had very weak syncros so you not only needed to H&T, but each down shift required a double clutch, as described by our trucking friend above, in order to keep the transmission in one piece throughout a race weekend. Now I do that out habbit, but my guess is that my transmission will show much less wear than you "just - throttle blippers".
Originally Posted by the blur
when I first started.. I couldn't get it.. so I did the second best thing.
I was slow, so it didn't matter, I was a novice.
I braked EARLY, very early. Then I would take my foot off the brake, downshift, blip the throttle, release the clutch, Then brake again. IT worked, I was not destroying the clutch, not screeching the rear wheels. The instructors could NOT figure out what the H@ll I Was doing, but it didn't matter. All they felt was the double braking.
Now I can heel and toe, but I'm probably doing more damage to the drive train now because I am not 100% proficent at it.
also, I COULD NOT LEARN on the street. You have to be hard on the brakes to get the pedals to match up properly... at least for me. So my entire learing was on the track.
Also, for any novices/intermediates who have trouble...I can heel/toe pretty darn good, but I have trouble in anything but racing shoes. Sneakers are actually worse than a rubber dress shoe. Sneakers are too wide. I am cheap, so I use wrestling shoes...same thing just not fire proof.
I forgot the change into my driving shoes one time and had trouble. I didn't understand what was going on, until I looked at what I was wearing.
If you are having trouble and are using sneakers, this may be part of your problem. I find the stock C5 pedals to be just fine, I also would imagine dexterity and shoe size make a difference as well. If you have small feet, I would imagine it might be more of a challenge.
