Eighty valves!
Old Jan 4, 2006 | 03:19 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Eighty valves!
http://www.callawaycars.com/v16/gallery/index.htm
http://www.callawaycars.com/callaway...ess%201%20.pdf
Old Jan 4, 2006 | 04:16 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
I was thinking about how much money it was going to cost to do a valve job. But I guess it doesn't matter if you got the money to buy one of these.
Randy
Old Jan 4, 2006 | 06:45 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
It reminds me of these http://www.falconerengines.com/
Used in P51 airplane replicas, boats,
and of course the Falconer Corvette in the Museum, it took a lot of work to lengthen the front to accomodate it.
Old Jan 4, 2006 | 07:51 PM
Gatorac's Avatar
Gatorac
If this thing sounds anything like the BRM V16 engine, I want one.
I'll build something to put it in.
Old Jan 6, 2006 | 01:19 AM
TrackDayLT4's Avatar
TrackDayLT4
Randy
From the picture it appears to be four Yamaha R1 head and cylinder assemblies on a common block. Any good motorcycle shop should be able to do the valve job. $750/head or about $3000 for the set of 4 doesn't seem too bad.
Cheers,
Lawrence
To Eighty valves!
