replace front calipers?
Old Jan 7, 2006 | 09:34 PM
Oyishdog's Avatar
Oyishdog
Default replace front calipers?
How often should you replace the front calipers on these cars? I assume the stockers can only deal with so much heat before warping - I think that is the cause of my brake vibration since I have gone through several sets of rotors with similar results. I was thinking about replacing the fronts before my first events this year...thoughts?
Old Jan 7, 2006 | 09:54 PM
davidfarmer's Avatar
davidfarmer
it really depends on the pads and the driver. You need to pull them off and measure to make sure they are still square. IE, you need to make sure the piston side and the outter side are parallel to each other. Also, you need to make sure the pistons haven't mushroomed out due to the heat.
They are pretty cheap, so if in doubt, change them.
Old Jan 7, 2006 | 11:46 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
yep Wilwood
Old Jan 8, 2006 | 06:24 AM
Lancer033's Avatar
Lancer033
Mine survived 2 years of track events and that was probably pushing it longer than I should have. Replaced with Wilwoods which I'm eager to try out at the track.
Old Jan 8, 2006 | 07:20 AM
larryfs's Avatar
larryfs
they will "open up" after many years of abuse. The "U" part will get wider, but only under serious abuse. I recently installed the GS calipers, and carry the aluminum ones as spares...
Old Jan 8, 2006 | 08:59 AM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
Regardless of which brand of calipers you have, it is a good idea to replace the seals at least yearly. The seal kit from GM is very cheap insurance.
Old Jan 8, 2006 | 09:29 AM
larryfs's Avatar
larryfs
I find the seals melt after the first event. I'm talking the outer dust seals, and I got tired of replacing them. The inner seals I have never had a problem with......
Old Jan 8, 2006 | 10:08 AM
ghoffman's Avatar
ghoffman
That is my point, replace them before you do. I think the seal kit is like $10 or something. Also, the old seals do not have as much piston pull back so the brake pads can drag more.
Old Jan 8, 2006 | 10:15 AM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
yehp, found that out too.
my stock calipers lasted 2 yrs (about a dozen DE's), put new stock ones on last yr-but am definitely going to go with an aftermarket this yr
Old Jan 8, 2006 | 10:33 AM
John Shiels
Gary means piston seals.
Old Jan 8, 2006 | 12:49 PM
Oyishdog's Avatar
Oyishdog
Yea, mine have two years worth on them and i think they are shot...I was orignally planning to go with the LGM 6 pot wilwoods, but i have other expenses i need to take care of...so the stockers will do just fine for now. Thanks for the input guys.
Old Jan 8, 2006 | 02:00 PM
John Shiels
get some mica shims
Old Jan 9, 2006 | 10:26 AM
95jersey's Avatar
95jersey
4 years on the stock brakes
They were shot...pad taper was ridiculous and pedal pressure was pretty soft no matter how often I bled them. I was also going to replace them with stockers again, but I couldn't resist the group discount on the LG Wilwood set up. It was perfect timing! I am waiting as they are getting powder coated in red to match the rears and they will be going on later this week.
Then the Dewitts and a new cam 2006 is going to be good.
To replace front calipers?
