Castrol SRF, and V710 question
Originally Posted by AU N EGL
Open the MC you might be suprised how much it looks like cola already.
I'm thinking Tom is right about the SRF even for street cars.
Received 8,928 Likes
If you are getting a large color change in your brake fluid over a half year's time you must be doing something I am not doing. I run the Ford Fluid and other than the fluid that is in the calipers have never seen any noticeable color change of the fluid in the MC. Even with the new 500 degree Ford Fluid and Wilwood H pads I have not boiled the fluid yet. SRF is a great fluid but an overkill. I can still bleed the complete system almost as quick as bleeding the calipers several times per year and still be $ ahead. The amount of fluid difference is mimimal when you realize just how little fluid is in the brake pipes.
Bill
Bill
Originally Posted by provette67
I run the 315/18 setup on the rear of my"stock" Z06 no problems.Go have some fun
As far as the thread goes the guy that we got our car from runs the 315's on the back in both the kuhmo and the hoosier on stock Z06 wheels and his is also "stock"
Originally Posted by Jess03Z06
I see the note about using one bottle of Castrol SRF all year and further that you just bleed the caliper not flush the system. That seems great, but does the open bottle not absorb too much moisture from the air once the bottle gets partially empty?
Second, I have seen many posts saying you can put the 18" 315 v710s on stock z06 rears. I run TT and have a stock suspension and stock rear brake ducts. Under heavy cornering, do you guys that run this combo get any rubbing on the fender or brake duct? I read all threads but couldn't find that exact combo question asked/answered.
Thanks!
Thanks!
