Caliper Replacement
I figure this abuse will eventually have a toll on the entire package. How can I tell when the caliper is getting to the point that it needs replacement?
Other than piston seals going bad, the typical caliper failure mode is for them to "spread". In other words, the two pads are no longer parallel to each other and to the rotor surface. This is usually evidenced by taper in the pads in a radial direction, the top of the pad (near the edge of the rotor) is thicker than the bottom.
When the caliper spreads it is junk. Nothing to do but replace it. T-1 racers see this at times, but I have never seen a caliper fail in this fashion from just HPDE use.
Hope this helps.
Frank Gonzalez
Is there a difference between the C5 caliper and the C5 Z06 caliper (excluding the pretty red color
)Frank Gonzalez
I'm in the process of changing my calipers today.....got 4 new Z06 calipers from Fred Beans for $350 + shipping.
Got my Motive bleeder this morning....gonna try it out tonight.
Running NHIS Monday....if you want to come up. John will be there, as well as a bunch of other vettes...
They make one specific for GM now. That is what I used and it was easy...
Thats what I bought.....
I still think the Wilwoods are head and shoulders above the stock Z06 caliper. Then throw in the cost of race pads for the new Z calipers you really have a reason to dump the stock Z set up for something better.
Yesterday, the performance of this system was fantastic at NHIS which is a heavy braking track. On one pass into turn one, I got a very late point by (with another forum member in the passenger seat) and I was thinking "Oh my god, I hope we make it" and we did, no problem. I felt like Jeff Gordon when he drove the Williams F1 car in that I kept thinking I was going to blow it, but it just stopped and I was thinking I could have gone even deeper.
I ran it all day with the fixed rotors (the black ones in the pic above, the floaters had an issue) and it was fantastic, no fade at all with the 97 compound pads on a very hot day. The track temp was almost 130 and in the sun it was 102. The rotors look great and the pad wear is minimal. The rotors were literally glowing bright red observers told me later.
At the end of the day I was very tired after 4 sessions each with 2 students plus my sessions. I had promised my friend Jim (he is a GT-2 driver) and Brian Cunningham (another forum member) a few laps in the car. I did a couple of laps with Brian, let him out, and was planning on only doing a couple with Jim but I saw a yellow Porsche GT-3 a hundred yards or so ahead of me and I just could not let that go so I stayed out and got him a few laps later. Overall, a really good day!
