Hawk HPS pads
Old 08-05-2007, 01:17 PM
RaleighSS
RaleighSS's Avatar
Default Hawk HPS pads
Are Hawk HPS pads ok for HPDE event at VIR?
Old 08-05-2007, 01:36 PM
RaleighSS
RaleighSS's Avatar
Default humm
May have found my own answer... looks like some people say they are not so good for HPDE....
Old 08-05-2007, 02:57 PM
Aardwolf
Aardwolf's Avatar
I ran some at Road America and did have fade, I could feel that the brake ducts would bring them back quickly though. There would be a series of corners and the brakes would just start to get ineffective then a straight away witch would bring them back to working. I have read the HP+ do better. I decided to just run Carbotechs and leave the HPS for the street.
jpobrien
jpobrien's Avatar
I have been using Hawk HP+ (one step above HPS) for HPDEs at Mid-Ohio and Putnam Park, and I seem to melt them off every time.
I'm going to switch to Carbotech 12s - front/10s - rear.
Old 08-05-2007, 03:00 PM
RaleighSS
RaleighSS's Avatar
Default cool
Seems like the stock Z06 Pad is best bang for the buck....
Old 08-05-2007, 06:02 PM
Lancer033
Lancer033's Avatar
marginal at best for roadcourse on street tires wouldn't even think about it on track tires, didn't like them
Old 08-05-2007, 06:28 PM
outnumbered
Support Corvetteforum!
outnumbered's Avatar
I am on my 2nd set of HP Plus. They have been very good so far for me.
They were fine at VIR.
I think a lot depends on drivers style and different tracks.
Old 08-05-2007, 07:56 PM
90Z51
90Z51's Avatar
I've learned my lesson with high perf. street pads on a track. I won't be doing it again. The pads need to be able to deal with the heat or they will start to tear themselves apart.
Old 08-05-2007, 08:55 PM
davidfarmer
davidfarmer's Avatar
they do fine for me, better on lightweight cars. They wear quickly, but at half the price of true racing pads, it's a comprimise I am willing to make much of the time.
Old 08-06-2007, 07:56 AM
PA Z06
PA Z06's Avatar
David are you running the HPS or the HP+
Old 08-06-2007, 09:42 AM
davidfarmer
HP+ .
HPS definetly will not stand up for too long.
On my ST2 car, the HP+ pads are awesome. Great grip, no fade, but the car only weighs 2950lbs (with me in it). In the C6Z06, I still experienced no fade (even doing 170 with slicks at VIR), but they required more pedal effort than a DTC70 or HT14.
Again, they performed well on both cars, and FOR THE PRICE are very good.
Old 08-06-2007, 09:12 PM
rudyarias
rudyarias's Avatar
VIR is rather easy on brakes if you're in the novice or intermediate HPDE group. The Z06 OEM pads will work. I would go to an aggressive pad if you are using R Compound tires.
To Hawk HPS pads
Quick Reply: Hawk HPS pads
