Guldstrand sway bar heim joints for C3
Old 08-27-2007, 03:54 PM
73jst4fun
73jst4fun's Avatar
Default Guldstrand sway bar heim joints for C3
Anyone using the Guldstrand sway bar heim joints on the rear sway bar for a C3?, looks like you need a bar with vertical ends and can not use the stock bar with the horizontal ends...?
Old 08-27-2007, 09:06 PM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
post a link if you can
Old 08-27-2007, 09:31 PM
73jst4fun
73jst4fun's Avatar
From Newton's book on Modifying your 68-82 corvette, references the heim joints with the sway bars, the ends on the rear bar are for a vertical mount to the heim joints. Wondering what bar mfg. makes one with the vertical end...
Old 08-27-2007, 09:38 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
from his on-line catalog
http://www.guldstrand.com/scripts/pr...?idCategory=43
Old 08-27-2007, 09:45 PM
burners
burners's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
That looks like it is designed to work with the stock bar and not an aftermarket bar that has horizontal ends. All is not lost, just use the kit for the front, they should work with horizontal ends.
Old 08-29-2007, 07:33 PM
73jst4fun
73jst4fun's Avatar
Thanks all for your input, I have an 3/4"aftermarket bar (VBP) on now, I have to locate an OEM bar with the vertical ends to use the Guldstrand heim joint links.....
To Guldstrand sway bar heim joints for C3
Quick Reply: Guldstrand sway bar heim joints for C3
