What tap/die do I need for C5 wheel studs/lugs?
Old 09-06-2007, 02:03 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default What tap/die do I need for C5 wheel studs/lugs?
I'd like to have them handy just in case I ever need them. What do I need to buy?
Old 09-06-2007, 04:06 PM
wallyman424
wallyman424's Avatar
12mm x 1.5
Old 09-06-2007, 04:57 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
tap and die won't do much good if you strip one. Keep some spare, good lug nuts, and some spare studs aren't a bad idea either.
Old 09-06-2007, 11:04 PM
Cobra4B
Cobra4B's Avatar
I do keep spares... but the rears are not changable at the track as you have to remove the hub.
Old 09-07-2007, 08:00 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
It is a real PITA to change them, but I did when I had everything apart for the Pfadt urethane bushings. I used ARP 2.5 inch long GM 12mm and cut them down to 2 inch (under the head). As you said, the rears are not easily servicable but at 2 inch long, (but not at 2.5 inch) the fronts are replaceable. I cut mine on my lathe, but with a hex die or nut that is split, it makes a nice clamp in a vice for a saw that cleans the thread as you turn it off.
Old 09-07-2007, 08:29 AM
varkwso
varkwso's Avatar
having a die to clean a "buggered" stud is handy - it will save a paddock replacement or the end of the day....
A tap is not needed - carry spare lugnuts and heave the buggered ones...
Old 09-07-2007, 09:53 AM
Cobra4B
Cobra4B's Avatar
Ok... well then what is the right size I need?
Old 09-07-2007, 09:56 AM
ghoffman
ghoffman's Avatar
M12x1.5
Old 09-07-2007, 09:58 AM
Cobra4B
Cobra4B's Avatar
^ thank you.
Old 09-07-2007, 10:06 AM
varkwso
varkwso's Avatar
see wallyman post above ....
To What tap/die do I need for C5 wheel studs/lugs?
Quick Reply: What tap/die do I need for C5 wheel studs/lugs?
