Do You Drive On Trailer, or Use a Winch ???
So far I have driven to track days but a trailer is definitely in my future for 2008.
Still trying to decide between an open trailer or enclosed but whichever I go with both of my cars (05 C6 & 97 C5) are very low w/ minimal front clearance.
I'm curious how many of you drive your Corvette under it's own power up on your trailer and how many winch your car on your trailer ???
If you winch on - where do you attach the winch hook or cable, looks like if you were to attach to a lower a-arm or suspension, the cable would destroy the front spoiler ???
THANKS for any advice !!!
Unless you have a race clutch, you can drive it on. Just have someone guide you up. Decrease the ramp angle and it shouldn't be a problem. I drove my '04 Z06 on to the open trailer and drive the C5 race car on to the enclosed all the time.
Thanks again
One of my pending trailer upgrades is a removable winch for the unexpected. You can buy a winch with the Sloan Kwik-Load from the factory, if you want to pay for it.
No problem driving up it, openning the door, and getting out. FWIW.
I had one event where a radiator hose popped off and I was very glad I had the trailer there! Just drove it up, drove it home and repaired it at my leasure in the garage. No big deal. I had another event where the battery died (they all seem to die after three years BTW) and once again I jumped it, drove it on the trailer and took her home.
One of these days a winch will be required and I see Harbor Freight has several low-cost models available. I carry a portable jumper that should have enough power to run the winch. Anybody know?
BTW, here's a picture of my trailer in the lowered position:
Good luck.
Good luck.
Do you back your car onto the trailer ???
THANKS
I always drive up the trailer front first.
I drive my '01 Z on to my open Featherlite trailer. It came with removal fenders on both sides. I have thought about getting a winch for the time I can not drive the car on to the trailer, but I think when that happens I can find enough people to help me push it on.
One thing you need to take into consideration before buying your trailer is what are you going to tow it with.
Sometimes on my open trailer, even with the removable fender, the door could rub on the trailer tires. I stick a foot out and help "nudge" myself up therefore taking enough weight off the car to allow me to open the door and get out... Too chunky for NASCAR style
I have a winch also and attach to the tow hook on the front of the car. Sometimes I winch and sometimes I drive. The latter if I'm lazy.
I drive on with my enclosed and the open trailer I used before that.
When I blew an engine at VIR - Toby pulled the car on through the access door with a tow strap - but if the car rolls there will be plenty of people to help you get it on the trailer - in my experience. If it does not roll it better be a good wench - I mean winch to get it aboard..
I can get out/in NASCAR style no problem even though I am about as slim as ZO6Cool (more flexible apparently) - but I often use my pit helpers/co-drivers to do that part....
I blew my motor the first day I had my trailer at the track 4-5 yeaars ago. Call tow truck and he go in front of my trialer and winched it in for 50 bucks. Nice removable winch is always good.
Received 8,928 Likes
Bill
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I drive mine up on an open trailer and can open the door to get out. I do drive upon 2 2x6s on the drives side so I get enough clearance
Have a Warn winch in the trailer, with a pull out controller, start the car leave it idling in neutral so that have easy steering and walk it up the ramp , have marked placement of wheel centers on floor of trailer , so that when its lined up reach in and turn it off, very easy not much contortion, The winch has come in very handy , at times when car is not easy to drive ( blown engine) ,
For the small cost , very worth it
