Want to see: pics of sheetmetal/fabbed dashboards in a C4
Old 12-07-2007, 11:12 AM
DVNCI
DVNCI's Avatar
Default Want to see: pics of sheetmetal/fabbed dashboards in a C4
Title says all.
Thanks!
Old 12-07-2007, 11:43 AM
Aardwolf
Aardwolf's Avatar
Originally Posted by RUKWKR
Title says all.
Thanks!
My favorite:
Old 12-07-2007, 12:51 PM
DVNCI
DVNCI's Avatar
Well there really is NO dashboard in that one.
Who's the girl?
Old 12-07-2007, 01:47 PM
ScaryFast
ScaryFast's Avatar
Check photos (second row middle)
I can't get to photobucket from my current location or I could post some better ones.
Not pretty but functional.
Old 12-07-2007, 02:17 PM
DVNCI
DVNCI's Avatar
Great, thanks. I'm looking for something with a little more shape than just flat across and I'm keeping my door panels as well. One of the coolest I have seen so far is what Jeffvette did to his where it roughly resembles the shape of stock dash.
Thanks again!
Old 12-07-2007, 07:28 PM
trackboss
trackboss's Avatar
I have some photos of custom dashes I built. They are not corvettes, but they can give you an idea of what can be done. If you want to see just let me know how to post a photo as I cannot seem to figure it out.
-V
Old 12-07-2007, 09:22 PM
DVNCI
DVNCI's Avatar
-V
You can just email em' if you want?
kalexander@fluidmaster.com
Old 12-08-2007, 01:07 AM
USAsOnlyWay
USAsOnlyWay's Avatar
You should still post em up after you get em if you don't mind.
Old 12-08-2007, 01:34 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Scrap carbon fiber makes great gauge holders. I built this in a afternoon for my iceracer.
Old 12-08-2007, 01:47 AM
kowalski340
kowalski340's Avatar
Old 12-08-2007, 03:00 AM
trackboss
trackboss's Avatar
I sent some photos off to RUKWKR. There are two dashes. One from my old #3 car and the second of the most recent car I built (still work in progress) and campaign. The wide dash is the old car and a simple piece of thin aluminum with a single fold along the top to stiffen the panel. There are some very light aluminum brackets that attach it to the roll cage cross bar. The other dash in the blue car is also a thin sheet of aluminum, but I built a lightweight frame for it that I welded to the cage and the dash panel attaches with screws. There are threaded inserts in the frame. The electrical panel is held on with some dzus fasteners for quick removal. The first panel is something that could easily be installed at home with minimal tools if you have a roll cage with dash bar.
-V
Old 12-08-2007, 01:37 PM
DVNCI
DVNCI's Avatar
QUOTE=trackboss;1563080615]I sent some photos off to RUKWKR. There are two dashes. One from my old #3 car and the second of the most recent car I built (still work in progress) and campaign. The wide dash is the old car and a simple piece of thin aluminum with a single fold along the top to stiffen the panel. There are some very light aluminum brackets that attach it to the roll cage cross bar. The other dash in the blue car is also a thin sheet of aluminum, but I built a lightweight frame for it that I welded to the cage and the dash panel attaches with screws. There are threaded inserts in the frame. The electrical panel is held on with some dzus fasteners for quick removal. The first panel is something that could easily be installed at home with minimal tools if you have a roll cage with dash bar.
-V[/QUOTE]
Thanks trackboss - here are the pics:
Old 12-09-2007, 12:13 AM
vetracer
vetracer's Avatar
Here's mine:
I like the big tach right in front
Old 12-09-2007, 03:08 AM
Slalom4me
Slalom4me's Avatar
Who's the girl?
She appears in several photos of the car hosted at CustomClassix.
I see that there is a footnote mentioning that Evan's car sold to a
buyer in NZ.
Old 12-09-2007, 09:25 AM
73-84 IMSA Widebody
73-84 IMSA Widebody's Avatar
C3........no *****
Old 12-09-2007, 10:49 AM
DVNCI
DVNCI's Avatar
Originally Posted by vetracer
Here's mine:
Yep - I'll put the tach right in front as well, as it should be.
Is there some type of covering over the transmission tunnel? It's hard to tell from the pic.
I'm actually wanting to recarpet everything including the tunnel and I'm wondering if they'll be able to "form" the carpet to the tunnel well.
Old 12-09-2007, 10:53 AM
DVNCI
DVNCI's Avatar
buyer in NZ.
If you go to that link you can get some more shots of the, um, car's headlights
To Want to see: pics of sheetmetal/fabbed dashboards in a C4
Old 12-09-2007, 10:56 AM
DVNCI
DVNCI's Avatar
I really like this shot of the harnesses:
Old 12-09-2007, 11:44 AM
vetracer
vetracer's Avatar
It's just a spray can application that is used as a trunk lining, I think - It is sold at automotive paint stores and even Pep Boys carries it.
Old 12-09-2007, 01:08 PM
ZBRA
Support Corvetteforum!
ZBRA's Avatar
Here is mine
The dash face was cut out of 1/8" thick aluminum on a water jet. I had enough sheet left over for one or two more faces. They will be cut out next week.
The dash top is an early C4 dash cap meant to cover a damaged or cracked OEM dash. It's a very thin sheet of plastic and weighs less than 2 lbs prior to installing hardware. You can see it here:
http://yhst-12260461708320.stores.ya...t/7002011.html
I now have the gauges installed, but no new pics. I still have a lot of wiring to do.
Quick Reply: Want to see: pics of sheetmetal/fabbed dashboards in a C4
