steering rack
Old 12-13-2007, 12:00 AM
Lancer033
Lancer033's Avatar
Default steering rack
Dumb question of the night. If my steering rack is going bad, how would I know? My car is making a clicking sound when I turn the wheel. Not sure what else it could be. Outside of the noise, everything feels fine from the driver's seat.
Old 12-13-2007, 12:12 AM
Sidney004
Sidney004's Avatar
Loss of fluid is one symptom as fluid seeps past worn seals.
Old 12-13-2007, 11:21 AM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
All turns or just sharp or "U" turns? If the latter ... any chance that the noise is coming from the diff ... chatter meaning additive needed?
Old 12-13-2007, 06:24 PM
johninar
johninar's Avatar
Mine just leaked
Old 12-13-2007, 07:35 PM
c4cruiser
c4cruiser's Avatar
A groaning noise when cold is also indication of a rack going bad. It's called "morning sickness"
Also look for signs of leaks at the boots at either end of the rack.
Old 12-14-2007, 12:36 AM
Lancer033
Lancer033's Avatar
can't be the diff. happens when the car isn't moving at all. No groaning sounds or leaks, just whenever i turn the wheel it get "click, click, click, click"
sway-bar end links or bad bushings are my next guess both of which i want to replace anyways, need to make some time to get under the car this weekend.
To steering rack
Quick Reply: steering rack
