Pfadt bolt in chassis bar
I think I want more than just a harness bar. Does anyone have thoughts on the Pfadt chassis bar. It is a simple bolt in, and a fairly nice looking piece. I would think that it should offer a little more protection then the harness bar for not that much more cash? Anyone with fit and finish comments for a c5 z06?
I think you drill holes on the top of the rear frame rails and insert an expandle threaded female tap. If done correctly with good hardware I think this could be a nice upgrade from a harness bar. I don't know. Probably just gonna weld one in......
The DRM one I have I can just grind off or even drill the welds if required but you still need to cut the floor in the rear.
