I found the bottom part of the gas paddle on the c6 is quite low, that makes it difficult for my heel to blip the throttle. The padde is spring loaded and it is sitting on a very steep angle. The top part of the paddle can be pushed down to raise up the bottom, like a lever. I've tried to jam the hinge to raise up the bottom, that makes it much easier to blip with my heel.
Does anyone has a good solution? Please share with me.
Most people just use the side of their foot. So you brake on the right half of the brake pedal and then roll your foot over to blip the throttle with the right 1/2 of your foot while still applying the brakes. Piloti shoes can help if you have smaller feet. It's called heel toe but most people just use the ball of their right foot and rotate it to blip. You can practice on the street at every stop.
That's how I do it with my other cars. The Vette is still new to me, not quite used to it yet. I found the gas paddle is very narrow, that makes it hard for me to blip with the side of my foot. I wear size 9. I can shift my foot a little more to the right, no problem for street driving. When braking hard on higher speed, I worry the ball of my foot may slip off the brake paddle.
I'll have to try out the Piloti shoe, or the diving flippers
Reason: typo
On the C5 some people with small feet have added a small platform to the left upper side of the gas pedal so they can tilt their foot over to blip the throttle. There may be some similar bolt on additions available on the aftermarket.
I put on the heel and toe gas peddle from Elite Engineering. Works great.
I just installed mine about 3 weeks ago and it's great! Have to make a little adjustment in my foot location because now I hit the gas when I'm braking.
I had used add on paddle before, but it can be dangerous because you may hit the gas paddle as well while you are braking. This is why the stock paddles are far apart and that the gas paddle is much lower than the brake paddle.
For this reason, I prefer to use my heel to blip the stock gas paddle. This way, the chance to hit both paddles at the same time is not high. I might be using the wrong technique though.
Bill
I have the narrow foot problem and wondered what the SCCA, NASA, PCA, etc. says about making the mod to the gas pedal to be able to heel blip. Spring Mountain had a car with an extension. It made it alot more fun. l
You are right about the Piloti shoes they do help but I can tell you that i wear a size 15 which they make and for the guys who say they have small feet it is still hard to heel toe a c6 with big feet.... the pedals are just not set up right to be able to do this...
I've always used this method, never liked hitting the gas with my heal. I tend to angle my foot so that I can use the top part of the foot on the gas pedal the heal more on the brake pedal. I only have a size 10 1/2 foot and the C5 pedals seem perfect.
