New upgrades for the track - testing in August @ VIR
"AlohaC5" Senior Member
The following parts were recently installed or will be installed next week in preparation for the Mazda Drivers HPDE at VIR - end of August:
I experienced a rare catalytic converter failure (honeycomb came loose and rotated inside the tube causing a clog) on the first day of the NCM VIR event. Still great hanging out on Corvette Hill with the gang and seeing many familiar faces. She'll be back stronger and faster!!
Ed Hutchings and his team at The HP Factory in Portsmouth, VA are performing their magic next week! The biggest challenge being the complete removal of the F55 RPO in a 2003/2004. The good news is this was done successfully by a shop in California and Connecticut. Ed said he's up to the challenge!
- Pfadt Camber Kit (-2.5 Front & -1.7 Rear and Corner Balanced)
- Pfadt Inverted/Adjustable Sport Shocks (Settings: 12 Front and 10 Rear)
- Pfadt Control Arm Bushing Kit - Poly/Aluminum Sleeves
- T1 sway bars (upgraded from Hotchkis sway bars)
- LG/DRM Front Brake Cooling Ducts (modified to clear Hoosier R6 315 tires on CCW C14 18x11 wheels)
- DTE Stage 2+ 3.42 gears (removing 3.73 gears)
- Perform engine diagnostics and verify dyno tune performance
Mike -- that thing was fast enough as it was. With these mods it will be even worse. With that much camber, you will eat street tires in nothing flat. So when are you just going to make it a full race car, add the cage and strip out the interior ?? See you at VIR ---
Thanks Mike, for the business, and the opportunity to help you out on your next round of mods.
You know me, I'm always up for a challenge. You've got a great running car. I'm proud to be part of that. Hopefully we'll get the F55 delete taken care of, and be able to provide some good information for the Corvette community as a whole.
I'm thankful that your recent loss of power was so easily diagnosed. I'd much rather deal with a backpressure problem than an engine that may be going south.
Thanks David. Seems I always had to shift into 5th as I entered the uphill esses - many "extra" shifts around the course - while I limited my revs to 6500 rpms. The new gears should give me the range I need to reduce my shifts while keeping me in the powerband. Mike
Mike - Now I see why you needed to sell all those nice brake pads!! You've gotta report back ASAP about the results of those tasty new mods.
Sounds like Ed's diagnosis of your brake booster failures at VIR (over the phone, no less) was SPOT ON.
have you ever used 3.73's? I'm really thinking about them.
Mike,
can you define "needless shifts?" I mean, I HATE shifting into 4th and feeling like I've fallen flat on my face.
Cruise-In VI Veteran
Hey Mike, Hanging out with you, Janet, and the three stooges made the event for me.
Ok, you got the brake booster thing-a-mabob issue diagnosed. The $64 question is...DID YOU GET IT FIXED FOR GOOD THIS TIME? I hope so. Ok, so you're getting more mods. I will just practice the point bys now and not hold you up.
Are you coming to NASA? We gots space on the hill.
Bob
Bob
Ed nailed the problem based on the symptoms I described over the phone at VIR. The vette won't be ready in time for the NASA event later this month because I need to get the requisite 'break in' miles on the new differential. We had a great time with you and Nancy - see you guys in August!
Yes. Free replacement of both cats and shipping to Ed's shop - great customer service for what many consider a rare type of material failure.
St. Jude Donor '05-'08
Nice mods
Regarding the 3.73s after running WGI and VIR this year with my new power I also decided to swap back to 3.42s.
I started out RR with 460rwhp / 401rwtq and 4.10 gears. I soon realized with rev limiter at 6800 that the 4.10 required too many shifts. I swapped out the 4.10s for GM built 3.73 and added the hardened output shaft. I ran this way for 3 years and was happy. When we installed the LS7 setup with 565rwhp / 540 rwtq I thought the 3.73s would be too much, but wanted to check it out before committing. Well first day at Pocono North I ran out of 4th gear, but didnt really care because that was a short track. 2nd day out I was at WGI and I ran out of 4th on the back straight, but had room to shift to 5th and downshift so it was not a real problem. At VIR the 3.73s killed me going through the uphill esses. I ran out of 4th gear at the bridge and thought if I shift to 5th gear where will I downshift back to 4th. I could wait until the short straight at the top of the esses or maybe do a double downshift before oaktree. I really didnt feel comfortable with either option so I decided to get rid of the 3.73s and go with 3.42 which should give me the added room I am looking for.
Oh well it is a complete circle for my gears, but I enjoyed getting back to where I started from.
My vette felt like it ran on rails before but now with the addition of the Pfadt Camber Kit, Pfadt Inverted/Adjustable Sport Shocks, Pfadt Control Arm Bushing Kit, T1 sway bars and T1 springs with an aggressive track alignment, she should be able to attack the esses and turns at much higher speeds. I will be comparing Traqmate data - before and after the mods - on the VIR uphill esses, roller coaster/hogs pen and NASCAR bend to verify the results.
