Differences between T1 and stock A-arms ??
I may need to replace my driver side lower A-arm/control arm,
What are the differences between the T-1 and stock? bushings?
its for an 03 Z
its for an 03 Z
Thanks,
I may have some physical damage to the arm itself not related to bushings. T1 arms are cheaper than New Stock, and cost close to low mileage used. So I was just wondering
I have an extra set of four lower control arms with poly bushings installed. $400 plus shipping if you want them.
meldog21@yahoo.com
Dog
meldog21@yahoo.com
Dog
Are you getting these from Gene or ??? and do you have stock numbers for them. I can't seem to get to any T1 parts in the regular catalogs.
To make a long story short, The nut that secures the ball joint to the knuckle came off after 2 months of working on the front suspension. totaly my fault
The lower controll arm rubbed into the front wheel damaging the wheel and control arm.
Luckly it happened at 35MPH
Sorry for bumping and old-ish thread but my question is the same as the title. So the only difference between the T1 and OE arms are the bushings? No changes in geometry at all? Im looking into the T1 suspension package (supposedly still available through a few vendors) which includes them and wondering if its pointless.
Also can anyone confirm if im reading the current T2 rules correctly that delrin is allowed as replacement for all bushing (including A arms), which essentially eliminates (if the T1 and OE arms are geometricaly the same) the need for the T1 apecific A arms?
Thanks,
Jonathan
Thanks,
Jonathan
Received 8,930 Likes
Bushings are the only difference. The T1 bushings are stiffer with less flex.
Bill
Bill
JJwins (07-31-2017)
Thanks,
Jonathan
Thanks,
Jonathan
