C4 Alignment Tuesday...
St. Jude Donor '03 & '05
Getting it aligned after rebuilding front etc. I have a 93, offset bushings, new everything up front.
I will be autocrossing it (BSP, fun only not going to win this class here), yet get barely a couple thousand miles a year here in Hawaii.
I have asked before, and looked at VB&P alignment recommendations. I know I cant have my cake and eat it too, but I was going to go a little aggressive for the street regardless.
I was looking at -1.75 front camber, 1/8 toe out and -1.25 rear camber with 1/16 toe in.
My Vette is lowered quite a bit too, and have ZO7 89 springs, 32S and 26S rear bars, and QA1's and BD+FG KD 315 r, 275 f.
WHat do you think?
WHat do you think?
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
You can always pull the shims before an event.
Aligning our cars is not that difficult
http://www.vettenet.org/align.html
But now it will perform on the track.
If you get adjustable links for the rear, which kicks you into SM2, then the rear is easily adjustable.
I have the offset bushings in mine as well. The 1.75, 1.25 does not sound aggresive enough. I am running 2.25, 1.75 right now and it is pretty good. Next time, I am going to bump it up to 2.75, 2.25. I have 3/32 toe in at the rear, I don't run toe out on the front but mine is not an autoX setup.
WHat do you think?
WHat do you think?
If you can get more in the front, do it. Even at -2.1, mine pushes but that's all I can get out of it.
What size tires are you guys running? There isnt much room in the back, for inner fenderwell clearnace?
Also, any pictures from the side to see what your alignments look like?
I like the 2.25-2.5 front, 1.75-2.00 rear. My rear is narrowed 13mm, so it will be tight.
Right now, I am running 275/40-17's up front and 295/40-17's in the rear, but I will be switching to 280/640-18 Hoosier slicks up front and 305/680-18 Hoosier slicks in the rear shortly on ZO6 10.5's. I don't anticipate a clearance problem but we will see.
Before, remember this is eyeballed alignment in driveway. So much for Lasix surgery
And after. Couldnt get any more camber due to rear tires rubbing inside too bad, as mine is narrowed and really lowered.
And this is what I ran originally in all my other autocsrossing.
C4's don't need a lot of rear camber. With a 315 or larger rear tire I wouldn't go more than -1*. A general rule of thumb is to keep the rears within 0.5* or the front, but this is certainly not a requirement. Does your car push or oversteer? These are the questions to ask prior to changing things...
I personally go about -2 to -2.5* front and about -1* rear with 275 tires front, 315 rear.
Well, I am not changing it now, too much money here in Hawaii. The posters in the beginning of this said I could/and they do, run good bit of negative camber in the rear. I have, over the years asked for alignments and I did what was within the requests (I did a search and looked at data), so if the rear is too much for autocross, it wont matter as I wont be too competetive in BSP anyways, but the alignment will be better than what I had.
It never really turned well and the back end would come around easily.
Oh well.
Oh well.
If you do it again I would knock the rear camber down to around 1 degree, up the rear toe to 1/4 inch total (with stock bushings) and knock the front caster WAY down 6.5- 7.0 max.
just my $.02
just my $.02
