Stock rim weight for 01 and 02-04?
Old 10-14-2008, 01:16 PM
slacker1201
Lifetime NCM Member #2497
Support Corvetteforum!
slacker1201's Avatar
Cruise-In 9-10-11-12 Veteran
Default Stock rim weight for 01 and 02-04?
Can anyone tell me how much of a diff. there is between the stock rims on the 01 Z06 compared to the 02-04?
Alcoa made the rims for the 01 and Speedline made them for 02-04. I didn't know if one would be better over the other for autocrossing. I know that the Speedlines are a good lightweight rim, but is the Alcoa just as good or just stick with the Speedlines?
Thanks for your help.
Old 10-14-2008, 01:57 PM
waktasz
waktasz's Avatar
The 01s are forged, and oh so slightly heavier, but stronger, AFAIK.
Old 10-14-2008, 04:07 PM
Slalom4me
Slalom4me's Avatar
Including the center caps, '03 fr/rr Speedline wheels weighed in at
19 lbs & 20 lbs respectively on a bathroom scale.
Old 10-15-2008, 09:30 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
This is what they have posted on the C5 General weights and measures sticky.
19.6 lbs, front; 21.4 lbs, rear - 01 Z06 forged - Src
19.2 lbs, front; 21 lbs, rear - 02-04 Z06 cast/spun - Src, Src
Old 10-17-2008, 02:01 AM
drivinhard
drivinhard's Avatar
The difference is pretty small, about .3 lb on my scales. Less variation than the last set of track rubber I got (4 identical tires, same batch, .5 lb variance from lightest to heaviest)
To Stock rim weight for 01 and 02-04?
Quick Reply: Stock rim weight for 01 and 02-04?
