Need some help with Koni 3013 sports ???
Old 12-06-2008, 06:38 PM
blkc6z51
blkc6z51's Avatar
Default Need some help with Koni 3013 sports ???
I have the Koni 3013 well the adjusters were working just fine but
now one of the front adjusters will not move. How do I free it up.
Thanks for any info.
Old 12-06-2008, 08:17 PM
gkmccready
gkmccready's Avatar
Really disliked those shocks on my '06 Z51...
Anyway, the only time I had them stick at all was at either full hard, or full soft, and honestly I just had to figure out which way to turn it and just use a touch more force to get it to free up.
Old 12-06-2008, 09:59 PM
blkc6z51
blkc6z51's Avatar
Ok I'll try that see how it gos they are at soft right now. Also I always stop the sweep in the middle so I would never go to far hard or soft
so this would not happen. Thanks
Old 01-02-2009, 08:19 PM
jw1
jw1's Avatar
3 out 4 of the Konis I had on my 05 Z51 froze up the first time I went to adjust them, which was about 1 week after they were put on. The shop that put them on had left them at full soft FWIW. I ended up returning them. Doubt if that helps you much, but there definitely is some type of problem with the design, which is too bad as I use Koni Sports on my other cars.
To Need some help with Koni 3013 sports ???
Quick Reply: Need some help with Koni 3013 sports ???
