Lap timer?
Old Jan 18, 2002 | 05:01 PM
David Lively's Avatar
David Lively
Default Lap timer?
I need a stopwatch-type lap timer for DE events (I'm not quite ready to shell out $200 for the HotLap system). Any suggestions and/or experiences?
Old Jan 18, 2002 | 06:48 PM
dgrace's Avatar
dgrace
Default Re: Lap timer? (David Lively)
Might not be what you're looking for, but if interested I wrote a little program to turn a laptop computer into a multi-lap-timer by running separate timers assigned to each number key across the top of the keyboard. The idea being that you have one person at trackside keeping lap times for a group of racers. It works, but your spotter has to be able to pick the cars out at a distance to be able to hit the keys reliably and get good times. Also an AC adapter for the computer helps a lot. I wrote it for use at motorcycle trackdays but cars should actually be easier because they're easier to spot. (and slower :jester !!!! kidding...)
In any case, it's worth the price! (free) You can download it from http://www.explodinghead.com/product...ats/index.html, about 2.5MB.
dave
[Modified by dgrace, 4:49 PM 1/18/2002]
[Modified by dgrace, 4:50 PM 1/18/2002]
Old Jan 20, 2002 | 12:08 PM
David Lively
Default Re: Lap timer? (dgrace)
Cool - I'd thought about writing something like that, but I really need an in-car solution. Thanks, though - I'll check out your app.
Old Jan 20, 2002 | 02:39 PM
OT Challenge's Avatar
OT Challenge
Hot Lap timing system by Longacre. The Inter-Comp system is supposedly really good, too. Both retail around $270.
Old Jan 20, 2002 | 07:30 PM
David Lively
Default Re: Lap timer? (OT Challenge)
HotLap is a bit out of my price range for the moment. I may just hard-mount my laptop or strap it down and build an RS232 button to place near the steering wheel. Hey, then I could write a TTS interface to speak the times at the completion of every lap. Hmmmmm... =)
Old Jan 21, 2002 | 09:02 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
TIMEX stop watch is cheap & multilap
To Lap timer?
