Self Alignment Question
Old Jan 9, 2009 | 10:19 AM
TedDBere's Avatar
TedDBere
Default Self Alignment Question
When you use the string method, what do you use for the "center of the car" to make sure the thrust angles are zero and your toe angles are equal on both sides?
Or stated differently, what reference point do you use for the center of the car on both the front and back when setting toe?
Old Jan 9, 2009 | 11:12 AM
69autoXr's Avatar
69autoXr
I don't reference the centerline; too difficult to find practically. I was taught to square up the strings by measuring to the wheel center caps, and making the difference in the distances (from string to center cap) front and rear the same on both sides.
I saw a good write up the other day somewhere online that I copied and saved. If I can find the link again I'll post it here.
Old Jan 9, 2009 | 11:19 AM
69autoXr's Avatar
69autoXr
Found that write up, here is the link:
http://wrx.grapon.com/techdocs/howto...0alignment.htm
Obviously the numbers don't apply but the method is similar.
Old Jan 9, 2009 | 11:24 AM
davidfarmer's Avatar
davidfarmer
you should download my guide. I use a laser level mounted to the rear wheels, to "center" them relative to the front wheels. Once you get the thrust angle close to zero, you simply adjust rear to symetric to keep the thrust angle centered.
http://www.davidfarmerstuff.com/align.pdf
If you have a nice straight 2x4, you can get a pretty close approximation also. Just hold it against the rear wheel , and see how where it hits the front (or how far out from it). Do on both sides. You must make sure you measure relative to the CENTER of the front wheel, as that is a fixed point in the suspension.
Old Jan 9, 2009 | 11:38 AM
midyearvette's Avatar
midyearvette
go to duntov corvette website....could be helpful
Old Jan 9, 2009 | 12:17 PM
froggy47's Avatar
froggy47
With the wheel center caps off, I measure to the axle to set up the string. If the car has never been wrecked I think that is pretty good. That is how Smart Strings tells you to do it.
I'm sure this can be improved on, but that's how I do it. I don't try for a centerline.
Old Jan 9, 2009 | 12:53 PM
jmartynuska's Avatar
jmartynuska
I use a bastardized version of the smart strings set up on my 'vette. Two PVC pipes, one across each end of the car supported by jack stands. Strings run along both side of the car - sewing thread works great, less sagging along the length. The trick is to have the strings equal distance apart on the poles. Measure from the left and right rear hubs to the strings, set the distance the same. Measure from the left and right front hubs, set the distance the same. Real tedious work. Because the strings are the same distance apart on the poles, the strings along the sides will be parallel to the center line of the car, even if the track width is different front and rear - or at least close enough for me.
Turn plates are plastic zip lock bags with a little wheel bearing grease in them.
I level the garage floor with pieces of plywood, 1/8 inch floor tiles, and a laser level.
Old Jan 9, 2009 | 01:29 PM
Life is Good Racing's Avatar
Life is Good Racing
Hi Guys,
Good thread. So how long does it take approximately to do your alignment?
I may be getting some garage space soon, so have been thinking about trying to do my own prep again. As is, the fluids change, brake bleed, clean, nut and bolt and alignment add up when paying labor before each race weekend.
Thanks,
s
Old Jan 9, 2009 | 04:51 PM
BEZ06's Avatar
BEZ06
I use David Farmer's technique for setting the thrust angle to zero, and I have Gary's (hardbarusa.com) toe plates with a couple of digital tape measures for setting the toe.
On the C6 Z06 the camber is very easy to adjust by adding/removing washers/shims behind the upper A-arm brackets:
The C6Z has exactly the same arrangement in the rear suspension so it's very easy to adjust camber both front and rear without messing with the eccentric cam bolts.
In my case I go back and forth from street to track and once you know you have a good street setup just make sure you work symetrically.
To go from street to track the common wisdom is that each of those washers is about 1/2 degree of camber. From the factory I had 4 washers up front and 2 in the rear behind each bracket. I take 3 out up front and both out in the rear.
The common wisdom on the forum also says that when turning the tie rods or rear toe adjusters, each flat is about 1/32 inch.
After I take out the washers I know I have to tighten each front tie rod 9 flats and tighten each rear toe adjuster 4 flats and I'm at my track camber and toe.
When going back to street, I just replace the washers, then loosen the front tie rods 9 flats each side and loosen the rear adjusters 4 flats each side and I'm done.
To set camber you can get a Smart Camber device, but I just bought a digital level. I just put it vertically against the wheel or tire (make sure to avoid bulges on the wheel where spoke webs bulge it out, or if on the tire avoid the tire bulge).
Overall, I'm pretty sure I'm within 1/10th degree or less for camber and within 1/32nd inch toe of what a laser alignment machine would do for me, and I can measure and adjust them any time I want.
BTW, hardbar has a really nice alignment shim kit and some studs that replace the bolts for those upper A-arm brackets.
Bob
Old Jan 9, 2009 | 09:24 PM
fatbillybob's Avatar
fatbillybob
I start with a flat floor then I measured the front craddle crossover member and the rear. I bisected the measure and drilled a tiny hole and run a wire front to back to be my chassis centerline. I adjust as I want then lower the car and roll it back and forth to settle the supension and check my measurement. If it is not right I alter it as needed and roll the car again. I do not understand the method where the car is on the jackstands supported by A-arms because I do not understand how you can get all the stichon our of the suspension (I.e. there is no way to settle the suspension on jackstands). In fact I have found it is harder to settle a vette suspension with transverse leafs than a coilover suspension.
Old Jan 9, 2009 | 10:38 PM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
In fact I have found it is harder to settle a vette suspension with transverse leafs than a coilover suspension.[/QUOTE]
So, what does that tell you?
Old Jan 9, 2009 | 11:12 PM
davidfarmer
So, what does that tell you?[/QUOTE]
It tells me that they should have put a roller bearing on the bottom of the spring adjuster!
Someone asked how long it takes to align....
I can measure the alignment on a car in about 4 minutes, including camber, castor, thrust angle and toe. I can take anywhere from 30min to many many hours to actually set the alignment.....depends on how picky the customer is.
Old Jan 10, 2009 | 07:57 AM
ghoffman's Avatar
ghoffman
Yes, I have said that for years, but there is not enough room to do that. The Delrin spring end kit we make does do that to a large extent. I think that is one of the major reason that coil overs do work better than the leaf sprngs. The Hardbar aglinment tool is very easy to use and is easy to calibrate any difference from the suspension on jack stands versus at ride height. Simply measure the toe before and after and note any difference with a Sharpie on the tool and set it to that while on the jack stands.
http://hardbarusa.com/uploads/image/...%20rev1(1).pdf
Old Jan 10, 2009 | 09:56 AM
TedDBere's Avatar
TedDBere
So if I measure from the hubs, without centercaps, do I have to adjust for differences in front and rear track, or are they the same? I know the front tires stick out more than the rears but is that because of wheel offsets or track differences? I want to make sure the string is parallel with the centerline before adjusting the toe.
And Dave, I notice that for camber measurement you suggest moving the level to the front of the rim to avoid the tire bulge at the bottom. I prefer to take two hub-centric measurments, one at the top of the rim and one at the bottom, and use the difference to determine the camber setting. Do you see anything wrong with the way I'm doing it?
Old Jan 10, 2009 | 10:36 AM
jmartynuska
Smart Strings take into account the difference in track by effectively forming a rectangle around the car. The strings are parallel as long as they're the same distance apart on the poles and the same length. If the distance from the hubs to the strings is the same left side and right side in the rear and the difference from the hubs to the strings left side to right side is the same in the front - and the measurement won't be the same front and rear - the strings will be parallel to the center line - no calculations required.
The real beauty of Smart Strings is they attach to the car - once they're set they're set, even if you roll the car back and forth. Wish I had a set of those.
Gary's stuff looks nice, too. Unfortunately my budget can cover a roll of sewing thread.
Old Jan 10, 2009 | 12:32 PM
69autoXr's Avatar
69autoXr
You don't even have to get the same distances from the string to hub left and right, as long as the difference in the front/rear measurements is the same left and right. Although I usually do shoot for the same distances left and right just to avoid confusing myself.
I've never heard of doing an alignment with the car on jackstands. I can see the benefit of doing it that way, but I have ramps that I drive on to to raise the car so I can get underneath to adjust the toe, and I have steel slip plates so I don't have to lift the wheels off the ground.
Old Jan 10, 2009 | 12:47 PM
fatbillybob
It tells me that I need to pay extra attention in settling the suspension which in my method means rolling the car back and forth.
To Self Alignment Question
Old Jan 10, 2009 | 03:40 PM
dbratten's Avatar
dbratten
Now that's a good idea. I use steel plates now but I think I'll drop a little Mobil 1 in four bags and see how they work as the bags will be much easier to move around and store. Mobil 1 works well to lubricate the 4x6" 0.25" plates I've been using.
To the OP -- I use David Farmer's methods and recommended tools along with the Pfadt Camber Adjustment plates and studs to quickly and easily go between street and race settings.
--Dan
Old Jan 11, 2009 | 08:24 PM
froggy47's Avatar
froggy47
[QUOTE=TedDBere;1568499350]So if I measure from the hubs, without centercaps, do I have to adjust for differences in front and rear track, or are they the same? I know the front tires stick out more than the rears but is that because of wheel offsets or track differences? I want to make sure the string is parallel with the centerline before adjusting the toe.
QUOTE]
If you measure across the string side to side (make equal)& then you are equi distant off each axle (I try to get within 1/64), then I think you are ok re being parallel to centerline, unless your axles are off if it's been wrecked.
If the car's been wrecked then I'm not sure how you would adjust for that. I think it has to be put back to exact true.
In any case I get good tire wear & my alignments seem to be doing what is intended re setup. My alignment knowledge is still a work in progress, but I think the more you do your own the more you learn & the better your setup will be thru the season.
Old Jan 11, 2009 | 10:42 PM
fatbillybob
[QUOTE=froggy47;1568516782]
QUOTE]
I'm not sure this is a good way because if you have an equidistant set-up from the hubs as the referrence point how do you prevent "dog tracking?" You have to assume with your method that the factory set-up was proper. It probably is but when you are tyring to improve laptimes and doing testing with different tires etc don't you want to "know" that you are starting from a solid referrence point? I think you want left and right equidistant from a centerline which automatically prevents dog tracking. In fact if you used the hubs how would you detect dog tracking? This is all pretty new stuff to me. I've been tinkering with my own alignment and scales for maybe half a dozen years so I think sort of basically.
