C4 Ground Affects
Old Feb 18, 2009 | 05:49 PM
Vector Vette's Avatar
0Vector Vette
Former Vendor
Default C4 Ground Affects
Looking to add ground affects to your C4? We have the best available. Originally designed by Jeff Nowicki of SpectreWorks with wind tunnel help from GM when he was racing in World Challenge.
Liteweight vaccum bagged fiberglass hood with heat extractor vents behind the radiator and above the brakes. Hood weighs just 22 pounds. (does not come painted red) Must be mounted with hood pins. $1300
Front Fascia, hand laid fiberglass with gelcoat finish. Does not come with brake ducts cut in it. $700
Liteweight vaccum bagged fiberglass Splitter/Undertray. Weighs just 6.5pounds. $700
Liteweight vaccum bagged fiberglass Rear Wing. Weighs just 6 pounds.
60" long x 15.25" wide. $900
Liteweight vaccum bagged fiberglass Roof. Weighs just 4 pounds. $500
Hoods are made to order, all other parts are in stock and ready to ship.
Robert Finlayson
Performance AFX Motorsports
630-844-0089
Old Feb 18, 2009 | 05:54 PM
66IISS's Avatar
66IISS
Does the wing come with all mounting hardware?
Old Feb 19, 2009 | 11:49 AM
0Vector Vette
Former Vendor
The price for the wing is just for the wing. I can supply the mount that I used to mount it.
Old Feb 21, 2009 | 09:09 AM
jwt1603's Avatar
jwt1603
How does the roof attach?
Old Feb 21, 2009 | 11:58 PM
0Vector Vette
Former Vendor
Roof is just a skin, you attach it with zues fasteners.
To C4 Ground Affects
