Clutch replacement chronicles...
Old 03-14-2009, 06:07 PM
wallyman424
wallyman424's Avatar
Default Clutch replacement chronicles...
Pulled out the drivetrain today:
gonna replace this:
with this:
AS SOON AS I CAN GET THE M-F'ing PILOT BEARING OUT.
Old 03-14-2009, 06:29 PM
Oyishdog
Oyishdog's Avatar
nice work
Old 03-14-2009, 07:50 PM
wallyman424
4 hours, 3 bearing puller tools and 3 deep bruises later... that bastard pilot bearing is out.
it took an amazing feat of man-strength to get that thing removed.
im out of town starting tomorrow, so I'll be buttoning everything back together next saturday.
Old 03-14-2009, 07:58 PM
CHJ In Virginia
CHJ In Virginia's Avatar
You have my sympathies having to do that job on the garage floor without a lift !! Next time you are trying to remove a pilot - take a propane torch or oxy acetelyne on low setting and heat the metal all around the bearing till it's good and hot. It will expand a couple of thousands and make it much easier to remove the bearing.
Old 03-14-2009, 08:12 PM
wallyman424
Hopefully there will be no next time. By the time this one wears out I hope to be making the big bucks ... then I can pay someone to do this ****.
Old 03-21-2009, 04:35 PM
wallyman424
Everythings back in the car and bolted up. Tomorrow all I have to do is bolt up the midpipe, replace the tranny/diff fluid and I get to fire her up!
I'm not sure that doing it myself was worth the backache, but its done now, no going back.
Old 03-21-2009, 04:47 PM
Git Er Dun
Git Er Dun's Avatar
Nice job doing it yourself.
In that 2nd picture I count at least 19 tires and 5 bare rims...NICE!
Old 03-22-2009, 04:45 PM
wallyman424
and its DONE.
everything is back together, car is running great. The thing sounds completely different with the new flywheel/pressure plate. All in all its a 22lb savings over the stock clutch, and you can definitely tell behind the wheel.
now I just have to relearn how to shift the damn thing, the revs drop so fast between upshifts.
Old 03-22-2009, 05:07 PM
CHJ In Virginia
My hat is off to you sir - anyone that will attempt and succeed in doing a clutch job on the garage floor without a lift gets GOLD STARS !!!
To Clutch replacement chronicles...
Quick Reply: Clutch replacement chronicles...
