Wider tires vs coil overs
Old 02-04-2002, 12:45 PM
dantos
dantos's Avatar
Default Wider tires vs coil overs
Which one of the two, wider tires or coil overs, would give me greater cornering speed. Thanks for you considerations.
Steve
Old 02-04-2002, 01:29 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Default Re: Wider tires vs coil overs (dantos)
Wider and/or better tires.
Old 02-04-2002, 08:02 PM
MAC95 6SPD
MAC95 6SPD's Avatar
IMHO the way to the fastest cornering speeds, Seat time, the best line, correct alignment for the track, better rubber then wider.
Hope this helps.
Old 02-04-2002, 09:11 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Default Re: Wider tires vs coil overs (MAC95 6SPD)
What are you running now? What size rims do you have?
Tires are first
[Modified by John Shiels, 8:12 PM 2/4/2002]
Old 02-05-2002, 12:11 AM
dantos
dantos's Avatar
Default Re: Wider tires vs coil overs (John Shiels)
i'm running stock wheels with 275/40/17 BFG g force KD's. I'm thinking of putting 17"x11" wheels with 36mm offset on the rear with 315/40/17 g force tires and leaving the front as is.
Steve
Old 02-05-2002, 01:04 AM
John Shiels
That should work. But as stated above track time is the best. The tires in stock size should be good too. There may be other things to do first as coilovers are a bunch of money. Set of tires and rims are costly too. Look for bang for the buck.
[Modified by John Shiels, 12:07 AM 2/5/2002]
To Wider tires vs coil overs
Quick Reply: Wider tires vs coil overs
