305/30/18 square setup OK for tracking C6Z?
Old 06-01-2009, 09:17 PM
m3to335
m3to335's Avatar
Default 305/30/18 square setup OK for tracking C6Z?
My buddy has access to some Toyo R888 305/30/18 scrubs and I was wondering if that would be an OK setup to run square on 4 C5Z rears on my C6Z. Im hoping it keeps it neutral but am not certain. Also its always nice to be able to rotate those bad boys
I wasnt sure if that OD was too small. Also, I've heard conflicting information regarding the traction control and abs.
If thats no good, is there any advance to...
275/35/18
335/30/18
Old 06-01-2009, 09:26 PM
dvandentop
dvandentop's Avatar
as long as the rims are not too wide for the tire the 305 will be fine. many people have run the 18 inch z06 all the way around. it all depends on how much money you are willing to plunk down on rims.
18 rear z06 all the way around IMHO is a good way to get a taste of sticky tires for minimal cost on your car
Old 06-01-2009, 10:03 PM
m3to335
m3to335's Avatar
I guess I was more concerned about the height (30) of the tire than anything else. But from the sounds of it, I'll be ok.
Old 06-01-2009, 10:06 PM
dvandentop
dvandentop's Avatar
run in comp mode and shouldnt have any issues
Old 06-01-2009, 10:21 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I've run all sorts of scrubs, from 285 - 315 in various diameters. As long as you run TPM's, you probably won't have any issues. I run with AH/TC shut completely off, and haven't had any issues even without sensors.
Old 06-02-2009, 06:57 AM
m3to335
m3to335's Avatar
Tire Pressure Monitors? I didnt realize that was a must. My bimmer threw a light but thats about it. Like I said before, I'm a Vette newb!
Where's a good place to pick up a set of those enexpensively?
Old 06-02-2009, 02:45 PM
Wah
Wah's Avatar
305s up front will tend to rub. Offset must be perfect to pull this and wheel can't be too wide.
Old 06-02-2009, 06:28 PM
m3to335
m3to335's Avatar
Can anyone confirm if 305s on a stock C5Z rear wheel will rub up front?
Old 06-02-2009, 06:52 PM
dvandentop
dvandentop's Avatar
i run 305 hoosier up front it does not rub unless doing a full lock on the steering wheel which one doesnt do on a road course so no worries
Old 06-02-2009, 08:58 PM
m3to335
m3to335's Avatar
Same wheels too huh?
Old 06-02-2009, 11:31 PM
dvandentop
dvandentop's Avatar
ccw 18x11 in front and 18x12 in back
Old 06-03-2009, 12:32 AM
Dreamin
Dreamin's Avatar
You want to take the factory 325s on 12" rims and downsize to 305s on 10.5" rims in the rear
Most everyone is running 12 or 13" rims on 325/335/345 tires in the rear!
To 305/30/18 square setup OK for tracking C6Z?
Quick Reply: 305/30/18 square setup OK for tracking C6Z?
