Hot August Days at Roebling and Road Atlanta
Old 08-26-2009, 08:14 AM
Timz06
Timz06's Avatar
Originally Posted by Z06_BluByU
Old 08-27-2009, 03:59 PM
varkwso
varkwso's Avatar
I met Tom and Tim, both at the same time, at a FL Crown PCA Roebling event in Jan 2002 I believe....despite their advice I stuck with it...
Old 08-27-2009, 07:38 PM
Z06_BluByU
Z06_BluByU's Avatar
Jeff,
do you run the 11" GS rims on all for corners on your C5Z?
thinking about that setup.. I know you have a ton of experience running this car..
Old 08-27-2009, 08:24 PM
Timz06
Timz06's Avatar
That's right, Jeff was driving a 4 cyl porsche, I remember thinking who is this obnoxious guy? And Tom, driving his mongoose c5, I believe I met him for the first time in front of the red roof inn.
Old 08-27-2009, 09:37 PM
Z06cool
Z06cool's Avatar
Ahhh....memory lane....isn't this special...:o
Old 08-28-2009, 08:32 AM
varkwso
varkwso's Avatar
Jeff,
I have run the 11" GS rims with 295 and 315 tires on all four corners. I like the setup.
Old 08-28-2009, 11:36 AM
Z06_BluByU
Z06_BluByU's Avatar
295 in front and 315 in rear?? any tire rub with that setup!?!
Old 08-28-2009, 12:40 PM
varkwso
varkwso's Avatar
With stock ride height - no. At high speed, high compression tracks (VIR and Rd ATL) it came really, really close.
I have run 295 on all four corners and 315 on all four corners. I went to 295s when the TT rules made me.
I have run 275s on stock front GS 9.5" rims with 315 and 295 on 11" inch in the rear. That may be marginally faster on a open fast track - but I like running "square" so I can freely rotate the tires where I need them on the car to get max life out of the tires.
Old 08-28-2009, 12:43 PM
varkwso
varkwso's Avatar
This is pre-ZO6cool days.... we met you at CMP ~2005 as I recall...
Old 08-28-2009, 01:00 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I wish Hoosier made a ~26" tall 295, in 17 and 18. I mentioned that there is a need for it in my last tire redemption letter.
As is, there is no way to run a staggered set up without running a smaller than front dia rear tire (295/30/18 - 25.3" with a 275/17 or 18 up front - 25.5")
Old 08-28-2009, 01:03 PM
varkwso
varkwso's Avatar
315 in rear work...
Old 08-28-2009, 01:04 PM
drivinhard
drivinhard's Avatar
315 in rear work...
not in TTA
Old 08-28-2009, 01:07 PM
  #33
varkwso
varkwso's Avatar
not in TTA
Quick Reply: Hot August Days at Roebling and Road Atlanta
