Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- Corvette Best and Worst Value Modifications
Important information to help you understand your Corvette.
C5 Track Car \ HPDE Conversion: What I have learned!
#201
http://www.engineeringtoolbox.com/th...ity-d_429.html
Although silicone is not listed there are similar type materials that I think would show a huge difference from SS to silicone. Metal will transfer more heat to the air not retain it.
#202
I understand that it's your life. It's just good to have the facts, because that will tell you what is really causing the problem. My engineering colleagues here test such things. It's the pads and brake fluid you need to avoid a sinking pedal (which may be boiling fluid as you say or expelled gases from the pad material).
A race pad is usually the best initial cure. The more aggressive, the more heat stays in the rotor which is made to take it. I might run a slightly too aggressive compound (sparks flying from the pad/rotor interface) but I'd rather overheat the rotors than anything else.
#203
Wow. Wish I had found this a month ago. Greatly appreciate the time and effort you put into to thread. Now I can stop pounding sand on the internet and spend sometime with the wife. You may have saved my marriage; you're a hell of a doctor.
I just jacked up the ol' credit card at Quantum, Hard Brakes and Elite. Those guys owe you
BTW-tried to order the Cryo Stop rotors for my base C6 (fronts) and they don't have them at Tire Rack. Called and confirmed it. WTF?
#204
#205
Terminal Vette Addict
#206
#207
with the economy I doubt much is short. If it is it is because nobody is keeping inventory on hand. What has been short this year or last?
#208
I think copper might be the best readily available conductor. But look at this, on Wikipedia it says diamonds are the best for heat conductivity... I did not expect that! Seeing as carbon is not a metal.
#211
Did I miss a section on traction control/active handling on vrs traction control/active handling off vrs competitive driving mode.
Just picked up a C5Z and will be doing some HPDE and AX, i would assume that most race prepped cars have this turned off in the computer. Is OFF the best option or is there some value to the competitive driving mode?
#212
Comp mode is good for when it is raining, and for when you first start tracking. After a few events I turned mine off, but it helped me to not spin when I was learning. Once you know the car, its a little intrusive at times.
#213
#216
First, I must commend you for such a thorough and accurate job on this thread that you have done. I also must console you that your medical practice must not be flourishing (as mine has been deteriorating) as evidenced by the amount of time you have spent putting this extensive thread together.
For the past 20+ years I have been doing some form of racing/HPDE and in 2004 decided on switching to a C5 (2003 Z06). I do not regret anything about all the track days, modifications, or on track breakages that I've experienced, since all maladies resulted in higher performance upgrades. The only real issue I now face is lack of funds and I'm jonesin' to be out there again. It has been two years since my last track day. After experiencing loss of motor due to timing chain breakage, loss of tranny, clutch explosion, header blowout during my last 7 track days, I no longer have the disposable income to experience another $3000-10000 day. The combination of lower income and higher expenses has put a halt to my track fun. Now for the most depressing part.
Since I no longer use this car as it was intended, despite running, driving, and performing the best it has ever done, I have decided to sell my car. After upgrading virtually everything on my car the right way, there is a very small market for this type of vehicle. Worst of all, despite $35,000 in extra parts on the car, it will ultimately sell for a few thousand dollars more than an unmodified vehicle with similar mileage. Do I regret modding this car to the extent I did? Yes, considering a Porsche GT3 would have cost me the same in the long run and would be worth considerably more now. The GT3 can be left bone stock, and is covered by warranty for 4 years. That's my only regret. But when the track and mod bug hits, you become addicted like a crack ho. It's hard to stop.
Once again, great job with this informative tome-like thread.
#217
I agree with this statement. Also, having the right tires allows the best modulation of traction so as to maximize your cornering while being able to reign in the car before traction breaks away. Hoosier R6 and Michelin PSC are the best IMO.
#220
The Pfadt mounts are much more rigid and there have been a lot of complaints of increased vibration from the use of these mounts.
Probably not a big deal if it's a full time track car, but on the street it could be quite annoying.
