Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
- Corvette Best and Worst Value Modifications
Important information to help you understand your Corvette.
C5 Track Car \ HPDE Conversion: What I have learned!
#221
To lessen wheel hops, anyone using just the transmission mounts? Any user thoughts on that? TIA!
#222
Whatever you do, if you get wheel hop let off the gas or you're break your drive train.
#223
I have experienced wheel hop twice, both times only short burst and the last time was last year bedding new brake pads decelerating from 60, hitting a bad section of bumpy road but I aborted the bedding process immediately.
Since then, I had installed Bilstein Sports and Hotchkis Sways. I am looking into Pfadt due to their claims of lessening wheel hop with the use of their trans mounts. I do not drag race, just doing what I can to preserve my enjoyment of the Vette and also in the process of changing out the GY to Michelin.
#224
Thanks again!
Actually, when you were braking that is not wheel hop and you won't do any damage. It's actually okay to do that because it exercises your ABS system.
I'm not sure what wheels and rubber you're running but I would look at that and a tranny brace from ECS or DTE to keep things together.
Wheel hop on acceleration is your enemy as that is when you break the transmission's main shaft or the differential.
Suspension jittering (trambling) is caused from rough roads and feels like wheel hop, but is a completely different animal because it is not being caused by hard acceleration.
If you are running run flats that is part of your problem.
#225
I switched to a smooth country road and completed the bedding process without further drama. The washboard section of the hiway was a poor choice initially although it was straight.
Although I enjoy the performance of my Z51 but never abusive, still on my original '05 GY SC and stock wheels. I am in the process of switching to Michelin but staying with run flats for peace of mind.
I don't ever drag race from a dig, only spirited running occasionally after the car is rolling. So I am just trying to do simple add ons to prevent the dreaded differential issue.
#226
Thanks for your continuing assist!
I would recommend some non-run flats and picking up a tire inflater kit like the ones used on the Z06's.
Non-run flats will give you a quiter car, better handling and pretty much eliminate wheel hop that you have been getting.
#230
Terminal Vette Addict
Welcome. Its an expensive hobby to start modding, and any insight on how to make it easier and cheaper is the best medicine.
#233
Thanks for the positive response! I jsut signed for 2 more SKF hubs form the FedEx guy as I write this. Soing to change out my bolts this go around on the SKFs with teh hardbar bolt kit because its getting old monkeying around with the silly stock bolts.
Next season I am going to start going through the engine compartment with a bigger radiator, oil cooler, etc. I just wasnt pushing the car hard enough this season that I got high enough temps to worry. I know next season will be a different story. And there is only so much $$$ in a budget per season. AND I overspent that amount I assure you!
Thats why I wrote this. After one full season of being out about every 4 weeks March - October I learned the hard way of how fast $$ goes in this sport. Im hoping the moeny and decissions I made will last better into next season.
I love seein gother track modded C5s out there. At the BMW club, second most commen car = C5. Porsche club = second most common car C5. Its just such a great plat form for a built up track car for far less $$ of cars that perform on the same par.
Hopefully this will be a sticky note, and save $$ for the newbies.
#234
power steering puken
Over the past 18 months, I have really enjoyed your read. So much there that I know I have missed a lot. I think there was maybe one mention of the power steering puke issue that many C6s out here in California see. Mostly seen this in non Z models, but worth bringing up. I split a power steering reservoir while still under waranty and it was replaced. But belched again so began looking at options. Do the C5Z's have this covered ? The C6Zs have a small finned exterior line and maybe that is sufficient?
#235
Hey Zenak
#236
For a couple of seasons , I had power steering oil vaporizing inside my reservoir; ended up dripping on my serpentine belt. Last season went well for me after changing out to a heat exchanger. I found this easier to install than switching out to a different underpully. I have one friend out here in California who is an instructor for Trackmasters. He went through 4 different designs in attempt to remedy this in his LS2 C6…..but he was really quick and knew how to push it on the track.
#237
Thanks for pointing this out, but maybe your C5 has a better design than my C6. Mine is just a 6 MM aluminum tube bent with a few 180 degree turns. Does yours have fins on it like the C6Z06 has? But even that design is minimal at best.
http://media.photobucket.com/image/r...ringCooler.jpg
#238
HPDE tires
Took your advice and got the Nitto: NT05 street tires for HPDE. Really like them and have ordered a new set for next season. Just wondering how much tread you need before you replace them? I am just about down to the wear bars. Just completed a TRACK DAZE event at VIR and tires still seemed to stick well. I am at the intermediate level and will probably stay there for next year.
#239
Lifsgrt (05-02-2023)
#240
So I've been debating on picking up a C5 for HPDE/Track Days. I currently drive a 2011 Camaro SS, and have taken it to two days at Texas World Speedway in College Station and one day at Grandsport Speedway in Houston. It didn't take me long to get bitten by the bug! My instructor at TWS was also driving a TT (don't remember if it was TTA or TTS) C5 Z06 which he took me for a ride in, and that didn't help the situation at all! I've decided that tracking my car is fun, but I think it's pretty limited on what it can do in the future. On top of the fact that I'm still making payments on it, I'm thinking my best bet would be to sell it and pick up a used C5. I think the Vette has much more potential in the future, and I would be able to pay cash for it once my car is sold.
Is the Z06 considered the better starting point over the standard C5? What mileage is considered too high if I'm going to be doing 4-6 weekends of HPDE a year?
From what I've read in this thread, I should pretty much stick to stock other than changing out all the fluids for the first couple events. Followed by brake lines, pads, shifter, and possibly seat/harness after a few events. After that I was thinking that since I'm in Texas, cooling issues would be a good thing to address. Maybe radiator, trans/diff cooler, oil cooler, and brake ducts. Once all that is done move on to suspension maybe followed with a few engine mods. Is this a pretty sound plan? I am thinking a budget of $3000-$5000 for the first year should be plenty for any upgrades/mods I would need to do (I'm not including maintenance costs in that price). My main goal is to make the car reliable first, then get to work on the driver, followed by engine/suspension modifications as the need arises.
I should also add the car will not really be a daily driver, but I would like to be able to keep it streetable for a year or two, depending on how into this I end up getting in the future.
Any thoughts/opinions on this?
