Help me fix my understeer problem
I think that most of the problem stems from the 275/335 combo. I ran 275/315 V710's for quite a while, and found a ton more turn in, and way less push with a 315/335 (18/17) combo, and a 305/315 (18/18) combo. I have not gotten to a square set up yet, but maybe next season. I like my fenders with factory clearance (at least for now).
G'luck
Fej
G'luck
Fej
Camber tilts the top of the tire in so that if it were a daily driver the insides of the tires would wear out, but since we are pushing/ sliding it gives you a a more equal distribution across the surface. In my case without the full race setup, my tires are tilting so more pressure is on the outside of the tire. So if I go full race, I'll use a little more of the inside and thus it might feel like I'm getting a bit more grip
Received 1,769 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I don't need to set my car up for street anymore. I can go pure track if I want to. That said, I'm having this revelation about Camber.
335 backs
315 fronts
would pretty much be a traction monster don't you think?
if you like the V710, the 305/18 would fit well enough on the C5Z rear 18x10.5's speedlines, they will clear almost all aftermarket brakes (good spoke clearance), they are very very light/strong, and you'd be square for better at track rotation. would be a good HPDE set up
are these repro 17x11's or OEM GM?
Problem is I've got so much invested in the 17 setup. I'm feeling the recomdations to go 18" though.
buy used 18's.
you won't have much out of pocket to make up the difference
having run 275's on the 9.5, and the 10.5, (back to back, same day/track) the stability difference is huge.
makes me wish I had some 11" for the 295s
I am running the 305/315 18" OEM Speedlines on my car currently. I spent weeks and weeks looking for an OEM set, and ended up finding a pair on the forums that a guy started blasting to have powder coated, and ended up changing his mind. Paid $230 shipped for the pair Fortunately I have a friend who I do a lot of work through that took care of coating them black for me.
IMO for the cost, you could pick up a set of 18's and sell the 17's and buy scrubs for various configurations for around the same price (outside mount/balance costs).
They also allow for future BBK upgrades etc. It took me a while to come around on the 18" option, but I think it allows the best combination of tire options, scrubs, clearance for brake upgrades, and performance. And they bolt on without issue, although you will rub the inner fender pieces at full lock with a 305+.
G'luck
Fej
G'luck
Fej
#33
When you get it re-alingned make sure the eccentric bolts are properly torqued. I had to re-torque every time I had mine done. If you mark them you can check to see if they've moved.
#36
I have found entering a corner too fast, for the tires on front (due to wear or whatever), also makes the car understeer worse. Luckily you can power up the oversteer with the throttle if there is enough track left. Laps are faster from an entry speed minimizing initial understeer.
But Chris is right - do not chase bad tires.
May do Roebling in Nov with Chin - undecided at the moment. Will be there on the 16th with SeatTime.
#37
Kidding of course, I do hope you make it. I'll get the full race camber, and I'll at least go back to my proven fronts and rotate them on Sunday. If I remember right, the right sweepers heading into the straight and then out of the straight are so fast you can get some push. Sure want to minimize that to have a good day.
#38
If you can go full time 'track' alignment.......
-2.6 front 1/8th toe out
-1.6 rear zero toe (1/16 -1/8th IN if you have sweepers)
Just my .02.....
275/315 isn't optimum......square works.......295/315 would be an improvement too
Just my .02.....
#39
I hear you guys on the tires. Money, money, money. Ordered a Corbeau A4, and a set of DTC70 pads. I've got an extra set of 315 rubber, but the 17X9.5 wheels I put them on didn't catch the whole rubber patch. I'll try the 17X11's on the front soon and if they work, well, another $250 for a pair of rims. I would be rolling on 335/315 and have my 275's as extras if needed.
#40
If you get behind me at Roebling - I will not block you. I have been known to even point/let EvoCool by.
