NT05 Purchase
Received 9,013 Likes
You'll like the NT-05. I did VIR on Monday and Tuesday and tried out my new NT-05's and loved them. In my run group, I still have to use a street tire and I thought I'd give these a try. They performed very well, got just a little sticky, and had excellent traction. Combined with a good track alignment I was very satisfied with this tire. I started at 35 psi but got up to 42 psi with the air temperatures close to 70 degrees both days. I'd say the 33 psi cold would be the way to go to get to 40 psi hot. I'll see how many track days I can get out of them and report back.
Yeah,
I thought the pressure was a little high too, but Nitto recommended hot pressure of 40 psi for track day. I typically would be at 36 psi hot on other tires, but I tried the 40 and it felt OK. I've also heard on this forum from a few that the NT-05 has soft sidewalls, and that may be why they say 40 psi.
Yeah,
Ok... Good info I will start off with maybe 32....
What sizes are you running?
Former Vendor
Charley,
It looks like you could run a bit less air and a bit more camber as it may balance them out, last longer, more grip, etc......They are worn quite a bit in the middle from the pictures, not to badly on the outside edge but to some degree but not quite rolling over on the sidewall. It may be a bit less precise but more grip and last longer, etc......from my experience with quite a few different sticky tires on the track. I have not run these yet or our C6 on the track though, I will find out once I figure out that pesky roll bar
Rick
Rick
Charley,
Rick
Rick
Thanks for the help.
Former Vendor
Pretty odd wear issues to say the least, from the pics and your info, then again I am dead tired right now, back is killing me, knees are screaming, I had fun in the shop today though so all good, sort of at least
There must be something in the way they wrap the belts to cause them to wear in the middle with low air pressure, I would guess!
I do not know the stock Z or regular alignment, never looked it up, I just do what I have to do to make it work. I probably have -2 up front for camber and -1.5 in the rear, a bit more positive front caster and a tiny bit of front toe in, zero rear but I will be playing with that a bit as things progress. I forgot to take notes but on my street tires it worked very well in spirited mountain driving on RE050A's.
It will be some time before I get to track the car but I will be reporting alignment settings as I figure them out
Rick
Rick
