adjusting rear T1 swaybar - how much difference would it make?
moved from outer to middle hole, wondering what should I expect, the car feels mostly neutral, slightly pushing mid-corner.
Just a guess on my part as our T1 bars are not adjustable but stiffening the rear bar should eliminate the mid corner push if not induce a bit of oversteer........
considering where you started, I would hope it would reduce your understeer and induce some throttle oversteer. Did you move both bolts or just one??? Should be a step in the right direction
I run a square tire/wheel set up, and have about 53/47 weight split. My car was decent on stickers, but the car would go to oversteer (on entry or exit) as the tires aged, with the old style non-adj T1 bar.
When I went to the adj T1 bar, I put it on the outside to soften it up, and the car has been truly perfectly balanced for my tastes ever since. It has always amazed me at how well it will trail brake now, you can really throw it in and get on the brakes hard and still have the rear end planted pretty good. CMP T4 comes to mind. Car is still a bit tail happy mid corner and off, but that's how I like it.
May have to reopen that investigation......
Interesting......I was considering putting the adjustable bars on and asked Jeff Kopp to measure the old bar vs the adjustable bar as far as where the hole placements were. He said the new bar's outside most hole was the same distance as the old bar and that the new holes were inboard of that. This would mean (to me) that the new bar would allow for 'stiffer' setup but none softer..........
CMP T4 is the perfect example for trail braking. I noticed though that my '03Z on stock shocks was horrible there. On '04 shocks it was great. Weird...
Should be interesting to hear how yours does there this weekend with the stock bars.
If you send me yours, I'll take mine off, weigh it to compare and ship it off to you
I should be getting ours back soon. Loaned them to a NASA guy to try out and he smacked the wall at St Louis last weekend. Not sure if they were on the car when he crashed........haven't talked with him since he got back. Will spec it out when I get it but that 43.5 number sure sounds familiar............
update. both middle holes was a little too much oversteer when applying throttle midcorner and a handful in the wet.
running middle hole on the left, outer on the right, just about perfect. pretty predictable over/understeer modulation with the throttle now.
I have our T1 bars back now too.......will measure this week and update.
In the wet, you should disconnect one side............completely.......
