18x10.5 Z06 Wheels on the Front ?
Will they fit okay on the front of a '02 non-Z06 with 305's or 315's?
Suspension is stock except for Pfadt shocks and is not lowered (yet).
Tex
Tex
I run Z06 rears on the front of my non-Z06 C5. Works great. They do rub my brake ducts alittle a full lock but nothing some duct tape can't fix.
I run 305 Toyo's or 295 Hoosiers. I suspect 335's on the front may wear through the duct but, in reality, how often do you turn the wheel to full lock?
John
John
I have had 305/30 and 315/35's on the front on the oem 18's. The 305's were better, 315's rubbed a bit on the inside fender wells, and were really close to the outer fender lip with -2.2 camber. (IE fully loaded up would likely clearance the fender a little)
I am trying 295/30 A6's this weekend, and I have a feeling it will be the best option fit wise.
G'luck
Fej
G'luck
Fej
