camber settings for c6 autox
Old 08-18-2010, 10:48 PM
NARIMAN
NARIMAN's Avatar
Default camber settings for c6 autox
wanted to ask
what camber setting for c6 on street tires for autox?
also i have the pfadt adj shock and not sure what is the best set for autocross
Old 08-18-2010, 11:39 PM
tomc8at
tomc8at's Avatar
[quote=tailshe;1575054161]wanted to ask
Thanks[/quot
Old 08-19-2010, 06:51 AM
OZ51
OZ51's Avatar
2 degrees neg. front and 1 degree neg. rear work with street tires, with 0 toe up front and 1/4" total toe in rear, as much front caster as you can set with these settings. Been running similar #s for awhile with decent steering response, controllable rear end, and good tire wear on the street. Can't advise you on shocks.
Old 08-19-2010, 10:41 AM
C6DuffMan
C6DuffMan's Avatar
+1 I'm running 1.7 front and .8 in back and could go a little more.
To camber settings for c6 autox
Quick Reply: camber settings for c6 autox
