17" vs. 18" wheels for C5 track car....
Old 09-21-2010, 04:36 PM
stano
stano's Avatar
Default 17" vs. 18" wheels for C5 track car....
I just bought a 2003 Z06 T-1 car. The car came with CCW classic 17" wheels. Besides the difference in turn-in, sidewall height and stiffness between the two, is there any benefit in going to an 18" wheel?
Old 09-21-2010, 04:44 PM
TrakJunky
TrakJunky's Avatar
The 18" slicks and dot-r tires are a lot easier to find used if you go that route with tires. . U can also run bigger brakes with the 18" setup. And 18's look better! lol
Old 09-21-2010, 04:50 PM
C5ZEE06
C5ZEE06's Avatar
congrats on the new car..post up some details when you get the chance.
Old 09-21-2010, 08:55 PM
stano
stano's Avatar
The car was built by Mike Tracy Sr. and Jr. out of Chicago. 2003 Z06. It has a full cage, driver side net, G2X data and AMB transponder, new Saferacer fire system, Accusump, Recaro XL Profi seat with Willans harnesses,removable Sparco wheel, Motorola comm system, Chasecam camera and mount, T-1 springs, T-1 sways, Moton double adjustable shocks, DRM brake cooling ducts, new crate motor and wiring harness, Ron Davis radiator, new Rockland short shift tranny and cooler, ARP long wheel studs, new windshield, front and rear tow hooks, 17" CCW's with A6 rubber, 2 extra sets of wheels and tires and a bunch of other extra stuff.
Car dynoed at 374.9 rwhp and 360.1 torque.
Old 09-21-2010, 09:15 PM
RX-Ben
RX-Ben's Avatar
What size tires are you running?
If are entertaining used Rs (like from John Berget tire), that may dictate your choice. I think Phoenix has the larger widths in either size. 17s are obviously cheaper new.
The extra sets of wheels and tires may help with choice as well.
Old 09-21-2010, 09:26 PM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Congrats Stan, you bought a very solid car. Good luck and happy miles.
Mike
Old 09-21-2010, 10:29 PM
C5ZEE06
C5ZEE06's Avatar
nice buy !
excuse my ignorance but..do the T1s use the stock intake and exhaust manifolds ?
Old 09-22-2010, 12:48 PM
RDnomorecobra
RDnomorecobra's Avatar
i'm pretty sure headers are allowed now
Old 09-22-2010, 03:04 PM
throwit
throwit's Avatar
18" Front, 17" Rear...best of both worlds...
Old 09-22-2010, 04:09 PM
yakisoba
yakisoba's Avatar
If you can join the Hoosier contingency program and win tires, you can have any size you like...
Old 09-23-2010, 10:01 AM
stano
stano's Avatar
Mike
Thanks Mike
Old 09-23-2010, 10:03 AM
stano
stano's Avatar
nice buy !
Headers are allowed now as well as front BBK's.
Stano
Old 09-23-2010, 10:14 AM
stano
stano's Avatar
295 front 315 rears A6's. I need to start looking at a good tire other than the A6 while I dial in the suspension. I was pushing allot with the scrubs in a few turns at Willow Springs. I still need to check the alignment and dial in the Moton's possibly.
Stano
Old 09-23-2010, 11:10 AM
SIK02SS
SIK02SS's Avatar
Hey Stan, if you ordered the AP kit from Gary already you're stuck with either 18's or wait until 949 releases their 17s next year..and those brakes would be an expensive paper weight at home
Check out the Forgestar wheels (Ryne is a vendor for them and gets great prices): http://www.forgestar.com/v1/f14.php
Also for tires, the Nitto NT-01's are great, and cash prices with these guys are nearly unbeatable: http://www.citytireonline.com/NittoNTO1.htm
wouldn't hurt while you're testing to try both the 295's up front and 315's to see which you like better.
Old 09-25-2010, 10:08 PM
argonaut
argonaut's Avatar
Using 3/8" worth of spacers you can get the stock 17" thin spokes to fit over Gary's kit. I haven't tried the C5 Z06 fronts yet. The C5 Z06 rears fit without any spacer (in case anyone was interested).
Old 09-26-2010, 08:03 AM
Timz06
Timz06's Avatar
I thought about the big brakes and 18's for my car, but it's not worth it to me at this point.
$2000 x 2 sets of new wheels -$4k
$4000 for brakes? total -$8k and not that much benefit.
Tim
Old 09-26-2010, 10:33 AM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I run 17 inch wheels with Wilwood BBK. I find used 315 enough and usually buy new 295 for the front from time to time.
To 17" vs. 18" wheels for C5 track car....
Old 02-26-2014, 03:34 PM
Chris Edwards
Chris Edwards's Avatar
Bringing this back up to the top.
I am considering a set of "T1" fitment 17" CCW's for my HDPE car.
Should I hold out for a set of 18's?
This is a fun car that will see the track maybe once per month, and obviously used tires when I can find them are always a bonus. Not trying to set any track records, just have fun and out-run a buddy's stock 2013 GT500.
Old 02-26-2014, 05:08 PM
Chris Edwards
double post
Old 02-27-2014, 09:00 AM
Hat_Trick_Hokie
Hat_Trick_Hokie's Avatar
17's worked fine for me. I was able to find R888, A6, R6 and V710 scrubs for cheap ($100 a tire max).
What what a coincidence, my non-CCW budget setup is for sale here : http://forums.corvetteforum.com/auto...osier-a6s.html
Quick Reply: 17" vs. 18" wheels for C5 track car....
