Need R888 pressures for this weekend .
I know it's been asked before but can't find it . What Starting pressures are people starting at with R888 's ,I know to start higher than the RA1 's (C6Z)? Thankx .
I've found that at 40+ psi hot those tires wear out in the middle.
Toyo Tires recommends the following general set up guidelines for the Proxes R888:
Operating Temperature: 160°F to 220°F
Hot Inflation Pressures: 32 to 38 (psi)
Camber: -2.5° to -5.0°
Caster: As much positive as possible
For the love of god do not set your tires at 35 cold or you'll be sorry!
Personally I set them to about 26-28 cold...
I'm running 35 front 36 rear cold and ending up in at 44/45 hot. This has kept my tire wear dead even and the tires stick extremely well. NOTE: This is on a C5 with 275s front and 305s back. I'm on my third set of 888s.
