Traqmate Tach signal in passenger footwell
Can anyone help me locating the tach wire near the BCM? That should be the best location to tap for Traqmate.
I know there is a white wire under the driver dash and also the white wire at the PCM and fuse block.
St. Jude Donor '05-'08
I wired mine right to the PCM.
97 - 98 Tach signal is at PCM, blue connector (C2), pin #35, white wire
99 - 04 Tach signal is at PCM, red connector (C2), pin #10, white wire
05 - 10 Tach signal located at PCM (behind passenger side wheel well, bottom connector (C1), pin #48, white wire. This wire also runs through the under-hood fuse block (C2, pin F6) to the instrument cluster (pin#5/connector #2) and to the Heads Up Display module (pin#4)
Note you will have set your the traqmate to 4 cylinder for the proper rpms.
here is a thread for under the dash
http://forums.corvetteforum.com/c5-t...-big-pics.html
Very helpful info. Hadn't connected my tach lead because couldn't figure out where to hook it up. Someone told me #1 plug wire. Well, that was wrong. Thanks. Jerry
