Poly bushing question
Old Apr 7, 2011 | 12:55 AM
  #41
sperkins's Avatar
sperkins
Originally Posted by brkntrxn
You guys are spending his money before he even runs his first TTA event.
That's because we've already spent all of ours.
Old Apr 7, 2011 | 01:08 PM
  #42
MYRX's Avatar
MYRX
You guys are spending his money before he even runs his first TTA event. You don't need anything other than As and Sways until you can consistently run for 2nd place. Then look at getting everything else to make a run at 1st.
No money has been spent that wasn't going to be spent anyway.
The facts:
1. Still need tires. Can't do the tires without the trailer! I do have an extra set of OEM wheels, but seems like I am learning everyone is running square 18's...correct?
2. A suspension set-up was a given. Poly bushings are on order.
3. Have not committed to TTA. I won't make that decision untill doing a few TT events. I have never really paid attention to the details at this point, I have only been a spectator while doing HPDE's.
The next two events will be a great learning experience.
Old Apr 7, 2011 | 01:11 PM
  #43
drivinhard's Avatar
drivinhard
you mean flatbed car trailer or tire trailer?
Old Apr 7, 2011 | 01:17 PM
  #44
RX-Ben's Avatar
RX-Ben
Spend all the time you can talking to other competitors. You picked the right car as there is a huge knowledge base. You are in a tough region and will likely get spanked at first, do not despair.
I have found that people are generally bursting at the seams to talk about this stuff at the track, so take advantage of that. Not that everything you hear is correct, but it should give you something to think about.
Old Apr 7, 2011 | 01:34 PM
  #45
gmccreary's Avatar
gmccreary
Bursting at the seams? Not the NASA SE crowd. They're a bunch of cheaters
Old Apr 7, 2011 | 01:49 PM
  #46
TGiuliante's Avatar
TGiuliante
Had Phoenix Performance install Delrin on my C6 - amazing feel and no squeeks like poly. You should inquire to see if you can get them for a C5
Old Apr 7, 2011 | 02:31 PM
  #47
MYRX's Avatar
MYRX
Flatbed type. I can use it in other applications as well.
Old Apr 7, 2011 | 07:57 PM
  #48
SoDiezl350's Avatar
SoDiezl350
Were these custom made or do they have a kit? Can you share what the price was?
I saw someone else post in another thread that they had Delrin bushings on their C5 and he said they were fantastic. I don't remember who made them anymore but I tried getting in contact with them and never got a response.
Old Apr 7, 2011 | 09:26 PM
  #49
brkntrxn's Avatar
brkntrxn
I'll politely disagree, but it is your money not mine. Just trying to give you some alternatives so you can spend your money on track time and not upgrades. Your car as it sits with a set of 275 A6s, a good seat/harnesses and Carbo pads (nothing else) is good for an easy high 1:30s at Road Atlanta, a hard driven 1:44 at CMP, a hard driven 2:08 at VIR Full and an easy 1:39 on VIR North.
The facts:
1. Still need tires. Can't do the tires without the trailer! I do have an extra set of OEM wheels, but seems like I am learning everyone is running square 18's...correct? So put a set of good street tires on your four 17's and a set of track tires on your 18's. I run 100 treadwear 275s on a set of 17s and 275 A6's on set of 18s.
Old Apr 7, 2011 | 09:56 PM
  #50
stevensa's Avatar
stevensa
Does anyone have any links to write-ups on how to install the grease fittings with the pfadt bushings?
Old Apr 7, 2011 | 10:02 PM
  #51
drivinhard's Avatar
drivinhard
I think OEM bushings aren't really an "upgrade" if you replace them, if you only do a few events a year they may last, otherwise, any hard track work on A6's will pull the arms off the bushings in short order. You are going to end up replacing them at some point anyway.
The other thing I've noticed (scott will back me up) from running my car stock vs not, is after bushings/shock bushings and set up, I got more useful (ie, faster) life out of the A6's. They were never as fast as they aged with the stock stuff, for whatever reason, you can be fast to the cords with a good set-up. Not sure of all the dynamics why.
Old Apr 7, 2011 | 10:03 PM
  #52
gmccreary's Avatar
gmccreary
01 C5Z, SLP Blackwing, Pfadt poly bushings, 04 C5Z shocks, T1 sways, Carbotech XP10/XP8, Corbeau FX1 Pro, Nitto NT555 RIIs = 1:39.6 at Road Atlanta
Old Apr 7, 2011 | 11:13 PM
  #53
brkntrxn's Avatar
brkntrxn
Just giving my personal times with my car, Greg.
Mark,
I understand the point you and Scott are making. I simply want to point out that you can be in the top half of the TTA field without all of that. Then again, my general rule is to upgrade something as it is needed or as it shows itself as the weakest link. Not before. I did enough of that crap with my Cobra and I wasted way too much money when I could have been driving.
-Kevin
Old Apr 8, 2011 | 07:24 AM
  #54
varkwso's Avatar
varkwso
Mark,
-Kevin
I won for years with a stone stock C5Z in TTA...when I built a car for the class it was faster - not sure if it was the car or better drivers from the seattime. The "backup" C5Z did very well.
Old Apr 8, 2011 | 07:42 AM
  #55
MYRX's Avatar
MYRX
Guys,
I appreciate all of the input. There is merit to all the points presented. But for me, the most important aspect remains getting the first TT under my belt and feeling comfortable in the car. Better handling was my first priority, (of course safety is a given). Therefore, I will have the poly bushings installed, and I will change the camber settings. Otherwise, the car will remain as it is meaning:
Larger sway bars, not T1.
Nitto tires, 555RII as on the car, 245, 305
Carbone Lorain CL Brakes, with castrol fluid, ss lines, etc.
Borla striaght pipes, Halltech intake...
TTS clasification - The results of the first TT won't matter, its about learning where I want to go in the future and getting in the game.
I started this thread, knowing I wanted a suspension improvement. I just wanted advice on the Poly-bushings, vs other alternatives and I think all of you have given me plenty of worthy advice.
Thanks again.
Old Apr 8, 2011 | 08:35 AM
  #56
Z06Tracker's Avatar
Z06Tracker
Welcome to TT. I won't offer any advice as you have had plenty. I counted five guys that provided input that are in the fast to very fast category. And, 4 of them are good at turning a wrench and setting-up the car. The other may be as well, but I don't know that well.
Wish you were running TTA.
Good luck!
Guys,
Thanks again.
Old Apr 8, 2011 | 12:05 PM
  #57
drivinhard's Avatar
drivinhard
TTS clasification
best mod for TTS/ST2:
To Poly bushing question
Old Apr 8, 2011 | 12:23 PM
  #58
gmccreary's Avatar
gmccreary
Good luck!
I'm not fast and I can't turn a wrench. That's why I use Perkins Performance
Old Apr 8, 2011 | 12:27 PM
  #59
TGiuliante's Avatar
TGiuliante
Phoenix machines the bushings themselves. i do not want to quote their price on the forum but they are three times the cost of poly. Give Joe a call at Phoenix - he is a top noch guy. I love the feel of the bushings, so glad I did it and NO noise or grease issues to deal with.
Old Apr 8, 2011 | 12:31 PM
  #60
gmccreary's Avatar
gmccreary
Kevin,
I was just posting my time with my setup as a reference for Jeff. Last month was my first TT and I'm looking forward to chasing you in the future.
Greg
