Brake Bedding question
Old Apr 29, 2011 | 09:44 AM
ssdeuce's Avatar
ssdeuce
Default Brake Bedding question
So I put new pads and rotors on bedded my brakes and cracked a rotor in the process so my question is do I need to bed my pads in again after I replace the rotor?
Thanks!
Old Apr 29, 2011 | 11:32 AM
Gordy M's Avatar
Gordy M
I was always told to bed the rotors with the old pads and then put in the new pads to continue the bedding process. Even then its a drive slow and gradually apply new bad material in the rotors, then some medium braking and finally start applying the brakes hard 4 or 5 time change pads and do it again.
Old Apr 29, 2011 | 01:47 PM
Liquid1's Avatar
Liquid1
Here's a very helpful article, with links to more related content at the end.
http://www.stoptech.com/tech_info/wp_bedintheory.shtml
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Apr 29, 2011 | 02:06 PM
torque*is*cheap's Avatar
torque*is*cheap
Definitely...you want to transfer some pad materials to the rotors' friction surfaces. I like to do about five hard stops from about 80 mph to 30 mph...preferably at night on a deserted road!
Old Apr 29, 2011 | 02:57 PM
JRitt@essex's Avatar
JRitt@essex
Supporting Vendor
Yes, you should do another bed-in. Here is a video and article I did on bedding in brakes (give it a minute to load, it is a substantial vid in high def). I discuss the theory, so it should be clear as to why you need to re-bed after watching it. Thanks.
Old Apr 29, 2011 | 06:21 PM
Bill Dearborn's Avatar
Bill Dearborn
Have cracked many a rotor at HPDEs. I change the rotor and then go out and take it easy (.7 or .8) for 2 or 3 laps slowly working my way back up to speed.
Bill
Old May 1, 2011 | 09:57 PM
RaleighSS's Avatar
RaleighSS
I have never herd of cracking a rotor in the bedding process .....
Old May 1, 2011 | 10:32 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
Thanks!
Kinda funny....
You may have went a bit overboard. But more likely it was the thermal shock to a new casting. With cast iron - especially the cheap stuff that most rotors are made from now...
-Warm it up slow - then keep it hot once it.s hot - and try to cool it evenly.
-Lesser heat cycles when new to slowly heat treat it.
It hates temperature differential, rapid temperature change or uneven heating.
To Brake Bedding question
