Hoosier Tech Tips
Old May 18, 2011 | 12:33 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Originally Posted by danbo56
A6 if you like to win...
Fixed that for ya!
Old May 18, 2011 | 01:30 PM
Z06Tracker's Avatar
Z06Tracker
According to the A6 instructions in the link provided, I think drivinhard has it right!
Originally Posted by drivinhard
well there's an oxymoron
Here's my initial run procedure:
1. Install
2. Take green flag, drive like an idiot
Old May 18, 2011 | 01:52 PM
ScaryFast's Avatar
ScaryFast
Originally Posted by jamsvet
News to me. For RR what would be a better option?
Depends on many many factors, but...A6 is the tire of choice. It is NOT true that R6's last longer, or that R is for roadracing and A is for autocross. In fact, testing by people with bigger budgets than mine have indicated that the A6's actually stay faster for more heat cycles than an R6 (6 - 8 vs 3 - 5). There is data everywhere that the A6 ("new" to "new" comparison) is 1 - 2 seconds faster than an R6.
Virtually everyone on the forum that is not restricted to a different brand of tire runs A6 for competition, both time trial or road racing. Does that mean it's the best tire? I'm not qualified to make that assessment.
The Kumho V710 is also pretty damn fast.
If you're not competing, for HPDE I'd run something like a Nitto or Toyo. Not as fast overall but they'll last 3 times longer before being rendered useless.
Old May 18, 2011 | 02:34 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by l98tpi
Autox (Hoosier A6) I run 30frnt/26rear. No complaints yet.
On our C6Z I am backwards from you. I run 26 front and 32 rear for Auto X. Car feels balanced. If I increase the fronts or drop the rears by even a couple PSI, the car will push on entry, center and exit.
Old May 18, 2011 | 03:25 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
stock suspension?
Old May 18, 2011 | 11:21 PM
JVetthead's Avatar
JVetthead
A6 if you like to WIN new tires alot...
refixed it for ya....
Old May 19, 2011 | 01:30 AM
jamsvet's Avatar
jamsvet
Now you guys tell me I should use A6s. Just got R6s. Have gone through two sets of R6s so I guess as soon as I wear these out it's A6s. I'm pretty much done with the mods to the car and we drive SM all the time so I'll be able to see just how long the tires last back to back. I'll keep track of how many sessions I can run on each. Talk to you in a year or so.
Old May 19, 2011 | 11:16 AM
95jersey's Avatar
95jersey
I would like to ask a clarifying question. You state the A6 basically lasts as long or longer than the R6, but your statement seems biased toward heat cycles. Yes, we know the R6's lose a good portion of their grip after several heat cycles, and it sounds like the A6's do not. But I like other have gone with R6's because I was told they won't cord nearly as fast as the A6. For an HPDE person, cording is more important than having a consistent tire. If the tire loses 30% of it's grip, but lasts longer (meaning doesn't cord as fast), that is probably a better value to someone doing HPDE. But are you also saying the A6 will last as long as the R6 (cord wise)?
Old May 19, 2011 | 11:25 AM
SIK02SS's Avatar
SIK02SS
In my experience this is true: as the R6 heat cycles the oils come out of the rubber and it gets harder and harder..thus, the tread doesn't actually wear as fast.
However, I disagree in not wanting a consistent tire for HPDE. If I were driving my street car on track (which I do occasionally), I would want a consistent tire for safety of mine and my cars' sake. But I run NT-01's on that car which stay pretty consistent.
Old May 19, 2011 | 01:00 PM
jamsvet's Avatar
jamsvet
Just don't see anybody saying:
Hoosier R6
Front tire pressure Cold XX
Rear tire pressure Cold XX
Hot pressure Front XX
Hot pressure Rear XX
Little help here.
Old May 19, 2011 | 01:06 PM
95jersey's Avatar
95jersey
Hoosier R6
Little help here.
What is your goal? Longevity or speed?
speed just under 30lbs cold, longevity, around 32lbs
Old May 19, 2011 | 01:07 PM
John Shiels
Hoosier R6
Little help here.
every car will be different according to setups/mods and desires. Also driving styles. I like 32 frt and 30 rear on my car and they usually end 42-44 hot depending on temps of the day.
Old May 19, 2011 | 01:15 PM
  #33
95jersey's Avatar
95jersey
From my experience the tires are best the first 3-4 events, then it is a slow process where they become less sticky. But having used many tires (treaded and non treaded). I have found a worn heat cycled Hoosier to be as good or still better than a newer treaded R compound. I have been using Hoosier for 10 years and never felt they were unsafe when worn down to cords. Do you have to adjust your driving style a bit, yes, but not that drastically.
The only tire I felt unsafe was when the Kumho's were de-treading. I had a set at the time (several years ago) that were recalled and after a few events, they were coming apart. I went with Hoosier from that time forward.
I would like to try A6's before I quit this car thing someday, but my concerns would be that I won't get the longevity from them (bang for the buck), and actually more important, abuse to the car. I already replaced a few bushings in 3 years that became deformed from the G's that R6's provide, I would only imagine it would be much worse with A6's. This is something people should consider, the more grip, the more abuse on the car (especially suspension).
Old May 19, 2011 | 01:19 PM
  #34
RichieRichZ06
St. Jude Donor '08
Originally Posted by John Shiels
stock suspension?
Nope, coil overs, bushings, Pfadt comp bars and -2.7* camber in the front
Old May 19, 2011 | 01:49 PM
  #35
jamsvet's Avatar
jamsvet
Goals are speed first. The car has Pfadt coilovers, Stoptech BB kit, SKW hubs, Brake cooling, Blah Blah Blah. No mods to engine or trans. Running speedline chrome Z wheels in stock size. Car has been cornerweighted by Guldstrand and aligned by him.
Old May 19, 2011 | 02:06 PM
  #36
95jersey's Avatar
95jersey
Just remember the racers don't care, but at setting below 30lbs, you will ruin and cord those tires very quickly just for a few tenths and at $1500 per set, after doing that a couple times, you may reconsider. If you are loaded, God Bless you and go for it
I like to have a set last me 1-2 seasons at that price, and proper tire management and driving style help me acheive this.
Old May 19, 2011 | 02:25 PM
  #37
John Shiels
kuhmos = junk and horrible tech support they suck!
To Hoosier Tech Tips
Old May 19, 2011 | 02:26 PM
  #38
John Shiels
sure the tires are giving you the push?
Old May 19, 2011 | 02:37 PM
  #39
froggy47's Avatar
froggy47
That's a puzzler. In 8 years of autox and 2 Vettes & comparing notes with dozens of other Vette guys I never came across anyone that runs less front & more rear pressure.
Not sayin it's wrong, just sayin.
Must be an unusual setup and/or driving style that makes it work for you.
Old May 19, 2011 | 02:57 PM
  #40
jamsvet's Avatar
jamsvet
I'm just a couple times a year guy but I don't want to throw money away. Would cold pressures of 30 lbs give the best balance for speed/longevity? Hot pressures at the track last time were LF35,LR32,RF31,RR31 Wound up cording the LF.
rf
