Input on Ford F250 Diesel (tow vehicle)
The brakes need to be bigger than your Corvette's wheels to stop that much trailer. Your springs need to be stiff enough to rattle your teeth when the truck is unloaded. And let's see how well we do in the winds cutting across the middle states these days when you have a trailer that weighs 4X as much as the truck that is pulling it along.
I'm about as far from a safety ninny as you can get around here, I've pulled trailers way too fast with way too much weight in them. But you can't win against physics, and tire contact patch is contact patch regardless of how much power you have under the hood.
Ahh, but you miss my point. It's not power that is the limiting factor here. My 1500 with a 350 HP hemi had plenty of power to do the pulling part. It's the stopping and controlling of a load that big that becomes an issue. The reason the trucks now aren't rated that high has very little to do with the motors. There's a reason you need a special license to drive commercial trucks, it's not all about money for the state.
To replace the DPF at Ford when it plugs up is 2000 bucks. The tune was 1600. No brainer. But then again I did have to get a new 1800 dollar clutch.
So far ive heard the torque converter will hold up.
Deleting emissions components voids your warranty and is illegal. Plus it's nice to have a truck with 765 ft-lbs of torque that doesn't belch black smoke. After 10k miles, the inside of my exhaust is not even black.
Replacing all early F-250 and 350 because of maintence cost,Injectors($300 each) starters and primary wiring loom problems.
contact patch doesn't change with tire, only rig weight or inflation pressure. When braking my truck, I have three of the four axles that have brakes on them, and the engine brakes very well also. I haven't pulled anything 4x the weight of my truck yet, but 2x yeah. I enjoy pulling and that enjoyment is increased by the amount of power that I have at my disposal.
I know you like to argue so I'm out. Do what you want.
I have a power programmer already. I also don't recall saying anything remotely resembling a doubt between towing differences in towed weight on the order of 2x vs. 4x. I'm sure there is a difference.
I bought a '08 F250 2WD Supercab (has the small rear doors) brand new and it now has 46,500 miles on it. It is my daily driver and tow rig. It took this truck a looonng time to break in. I didn't start seeing decent fuel mileage until I was around 30k miles.
On around town short trips, eg 5 miles, my mileage will hover around 14.5mpg. However, on interstate cruising, I can average well over 18mpg as long as I keep it under 70mph. Anything over 70 and my mileage will drop to 16+.
Towing an open trailer with my 03 Z06, I can get anywhere between 14-16mph keeping it below 70mph, depends on where I am towing (hills or flats). I will say, I LOVE the power of this truck, the BRAKES and the stability.
Diesel Particulate Filter/Regenerative crap: As soon as my warranty runs out at 100k, this system is coming off my truck at 100,001. Anytime this thing kicks in, my mileage drops. I will say the system works for the environment as my truck has rarely had any smoke come out of it. But it kills my mileage when it kicks in.
Besides the coolant overflow bottle recall and a TSB reflash, the only issue I have had with it was the intercooler. The design of the original intercooler would cause condensation to pool in the bottom. So if you were going along in a stead state of cruise (ie freeway driving) and eased into the accelerator, I would get steam from the exhaust pipe and a shuddering through the entire drivetrain. This only occured in humid, hot weather. I found a TSB about the intercooler, had my local dealer change it out to the new design and haven't seen the issue since.
The one other thing that I do not like is the open differential on my 2WD. I can do a one wheel peel for as long as I hold down the pedal. This has almost gottem me stuck in wet grass on more than one occassion.
-Kevin
-Kevin
I have an 08 F250 Job 1 with the spartan tune and (the last) 6spd manual. Plainly said, It hauls ***. Did have to get a south bend clutch to hold up to it, But Ive had no powertrain problems.
Only issue ive had is im on my second radiatior. Apperently these things leak like a spring. I think Job 2's got rid of this issue.
With the tune im getting 11 mpg loaded (20,000 GVW)at 75 MPH and up to 22 mpg at the same speed unloaded.
Same issue with the radiator. Pricey replacement. Just weeks over warranty.
Had some cutting-out nonsense. But it wasn't the " Crap In The Tank " recall, just a re-flash of the computers and good to go.
We have four Cummins in 3/4 Service bodies to compare. Those have 300,000 miles. We'll see how the 250 does?
TJM
